DarinB's Avatar
SSI install question.
Removed all of the exhaust studs/nuts today with heat and no broken exhaust studs. Interesting, though. 10 of exhaust studs came out instead of the nut coming off. I assume this is not a problem and I should just buy new exhaust studs and replace?? Just curious because I didn't expect it to happen that easily and with that many head studs out.
Darin
Old 07-25-2006, 09:04 PM
disband
juanbenae's Avatar
i had a couple do that. if i recall you are to put a bit of loc-tite on them. reseach that though, it has been a while.
Old 07-25-2006, 09:33 PM
Author of "101 Projects"
Wayne 962's Avatar
Nah, the Loctite is somewhat irrelevant at cylinder head temperatures.
-Wayne
Old 07-25-2006, 09:55 PM
Now in 993 land ...
aigel's Avatar
I certainly would put new studs while they are out anywah, as the old ones tend to embrittle from the heat treatment they received over the years. Wayne is right, the loctite does not hold up to high temps (Heat is how loctite it is removed if you ever need to get it off). Just get the stud in snug and if it comes out again next time you work on the exhaust, put it right back. If you put antiseize on the nut side, they may never come out again.
George
81 SC (sold)
Old 07-25-2006, 10:05 PM
DarinB's Avatar
Thanks! Wayne, looks like I'm going to be calling you for new exhaust studs tomorrow.
Darin
1995 993 - Black/black, RS splitters, brake ducts
1978 SC - "Toyo Spec" - Completed
Old 07-25-2006, 10:14 PM
