Changing CV boots
Is there any tips anyone has for changing the rear CV boots. I have 1 torn and thought I would replace them all. Do I need to replace anything in this job other than the grease??
Thanks, Kim
Old 01-07-2009, 08:28 AM
abit off center
cgarr's Avatar
Pretty straight forward, just a snap ring, there is a spring washer under the joint holding pressure on the snap ring so be aware of that, it is messy.
______________________
Craig
G2Performance
Old 01-07-2009, 08:33 AM
Senior Member
Superman's Avatar
Disassemble them, clean and inspect. If you see blemishes on the race surfaces, consider replacing them. An alternative would be to reverse the shafts. Place them on the other side of the car. This will cause the balls to ride on a new surface, instead of the old worn surface.
Mocha 1978 911SC. "Coco"
Old 01-07-2009, 08:46 AM
I agree with Superman, inspect them well.
Do you know how long the boot has been torn?
I had torn boots on one side and didn't know how long that condition existed. I opted to replace the whole axle with one from our host here.
Sure glad I did. The car is much quieter now and I doubt cleaning and regreasing would've fixed the old one.
You'll need gaskets and might consider replacing the bolts too.
Scott
'78 SC mit Sportomatic - Sold
Old 01-07-2009, 08:56 AM
I too just did this job. I had two torn boots on the passenger side axle. I took it all apart inspected the joints and determined the outer races were too worn to re-use. I went with a complete new axle from our host along with gaskets and some extra grease. I also replaced the bolts (at .60 a piece it's cheap insurance) and new schnoor/belleville washers. It went well.
I found the plastic hand brake guides/clips that attach to to the suspension arm was cracked. I ordered up replacement pieces, but I think I may need to disassemble the rear brakes to do it.....dunno.
Good luck!
1973 911T | Four owner car | My stewardship (2008-Present)
1972 VW Super Beetle | Two owner car always in the family | Gone, but not forgotten
Old 01-07-2009, 09:08 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The search function is your friend here. Warren Hall (Early_S_Man) was always kind enough to share the incredible amount of information and experience he had. See the link below
CV Joint Repair Bentley Manual Disassembly and Rebuild Procedure Courtesy of Early_S_Man
Kevin L
'86 Carrera "Larry"
Old 01-07-2009, 10:13 AM
AutoBahned
RWebb's Avatar
agree re going whole hog if you have to pull them to replace a boot
replace all boots; clean/inspect/repack with new Quality hp grease
replace Schnorr washers
inspect bolts & moon plates (install moon plates if not present - used are cheap; new they are cheap insurance)
Old 01-07-2009, 11:13 AM
