dropped a washer inside the engine
guys I was taking out the engine thermostat (PITA) and dropped a very small 2mm washer inside. I tried to grab it and felt it but it slipped away and it went inside the engine. if I drain the engine out whats the chance the washer will come with it.
ouch
I would hate to be in your shoes . I have dropped a washer in the case during reassembly and it was a pain to get it out . I cant emagine it coming out by draining the oil . However it is worth a try . I would also try paraying before hand .
Original Owner
Depending on the washer ...it's not a hardened steel bolt...it'll just get chewed up and come out in the oil after a few thousand miles.
You didn't drop it in the sparkplug hole..
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
I'm with Bill
Maby a small magnet on the end of a flexable hose, like some vac line. Just a thought. Good luck
Electrical problems on a pick-up will do that to a guy- 1990C4S |
sudo apt-get purge 930
but it might work for this.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Just don't lose the magnet too! I have a small flex-snake mounted magnet that has helped out a lot, but it's gotten snagged before during fishing expeditions.
Hopefully with the agitation and flow of the oil, the washer will make it to either a corner, low point, or filter. Is your oil drain plug magnetic? |
yes its magnetic
there are magnets on flex arms that have a cover you can retract to turn it off/on - Griot's has one
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
