| Registered Join Date: Jul 2006 Location: huntersville
				dropped a washer inside the engine
			guys I was taking out the engine thermostat (PITA) and dropped a very small 2mm washer inside. I tried to grab it and felt it but it slipped away and it went inside the engine. if I drain the engine out whats the chance the washer will come with it.
|  07-30-2006, 07:50 AM |
| Registered |
				ouch
			I would hate to be in your shoes . I have dropped a washer in the case during reassembly and it was a pain to get it out . I cant emagine it coming out by draining the oil . However it is worth a try . I would also try paraying before hand .
|  07-30-2006, 07:54 AM |
| Original Owner Join Date: Dec 2002 Location: San Antonio, Texas
			Depending on the washer ...it's not a hardened steel bolt...it'll just get chewed up and come out in the oil after a few thousand miles. You didn't drop it in the sparkplug hole..
				__________________ tsuter 78 911SC Turbo Targa Thaaaats Right!! | ||
|  07-30-2006, 08:09 AM |
| I'm with Bill Join Date: Jun 2005 Location: Scottsville Va
			Maby a small magnet on the end of a flexable hose, like some vac line. Just a thought. Good luck
				__________________ Electrical problems on a pick-up will do that to a guy- 1990C4S | ||
|  07-30-2006, 08:14 AM |
| sudo apt-get purge 930 Join Date: Jul 2006 Location: Brandon, FL
				 | Quote:
  but it might work for this.
				__________________ Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey | ||
|  07-30-2006, 09:31 AM |
| Registered Join Date: Dec 2005 Location: Vancouver, BC
			Just don't lose the magnet too!  I have a small flex-snake mounted magnet that has helped out a lot, but it's gotten snagged before during fishing expeditions. Hopefully with the agitation and flow of the oil, the washer will make it to either a corner, low point, or filter. Is your oil drain plug magnetic? | ||
|  07-30-2006, 09:52 AM |
			yes its magnetic
|  07-30-2006, 10:28 AM |
| Registered Join Date: Nov 2004 Location: Greater Metropolitan Nimrod, Oregun
			there are magnets on flex arms that have a cover you can retract to turn it off/on  - Griot's has one
				__________________ "A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off | ||
|  07-30-2006, 11:38 AM |
