Diss Member
Quicksilver's Avatar
Euro H4 picture request
Does anyone have a good picture of the inside of an H4 showing the layout of the wire retaining clips? I have a friend who disassembled his to paint it and can't remember how the clips go in. I thought I had a pic from my install but came up blank.
I don't really want to pop mine off so let me see yours!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-29-2006, 07:43 AM
khamul02's Avatar
I took pictures of that before I dissasembled mine to have painted. It will be monday before I can dig them up at the office. Putting them back in is a pretty easy process. It was those long set screws that gave me fits. They had a washer clamped down on them that I had to cut off and when I put them back together I had find a replacement.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 07-29-2006, 08:57 AM
khamul02's Avatar
This is from another post. Not the best pic from putting those back in. The key is there are 2 sizes of clips. Make sure each light has equal amounts of each. I think the longs ones either go all on one side or are equally distributed throughout the assembly. My pics will clear that up if someone else doesn't.
Tom Hutchinson
Old 07-29-2006, 09:09 AM
Diss Member
I have a picture of mine that is pretty similar to the one above. I am almost certain that I took one that showed all the clips but I can't find it.
BTW - I never noticed two sizes of clips when I was working on mine. If there were 2 different sizes I didn't differentiate between them when I put them together.
Old 07-31-2006, 07:25 AM
khamul02's Avatar
I'm not sure why I'm thinking there were two types of clips. I just seem to remember there were. Maybe not sizes but different type. Anyway here is one of those images. I have several more from different angles if this one is not what you need.
Tom Hutchinson
Old 07-31-2006, 09:02 AM
Diss Member
Thanks Tom. That picture is perfect! I will pass it on to my friend.
Old 08-02-2006, 12:38 PM
khamul02's Avatar
no problem
Tom Hutchinson
Old 08-02-2006, 12:48 PM
Wash. State
nesslar's Avatar
Ah, yes, digital cameras! Good picture! Always a good idea, especially for "newer" DIY types to have a decent "before" picture or two (or TEN! ) so as to be able to ascertian where that spare thingy you end up with was supposed to go.
But seriously, not a better reference than a pic of your own machine/assembly prior to "going in there."
I think that you simply overlap a bit and go on around 'til the clips are gone? Maybe run a pattern, like tightening lug nuts?
Old 08-02-2006, 01:02 PM
