Fuse question
I went to replace my fuse for glove box, interior lights, and clock which according to the manual requires a 5 amp fuse. The blown white fuse is 8 amp. If I replace it with 8 amp should that matter or should I get a5 amp fuse?
Old 12-11-2017, 04:06 PM
Hi Rx,
It depends why the fuse blew. If every connection and component is perfect, then the difference between 5 and 8 amps might not matter. Might as well put in the correct one though.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 12-11-2017, 04:21 PM
Thanks Dave. I accidentally caused a spark trying to fix my glove box light and blew my fuse, which was diagnosed by fellow pelican yesterday. Just having a hard time finding 5 amp fuse. Plenty of 8 amps around.
Old 12-11-2017, 04:37 PM
I would buy 1 or 2 5 amp fuses if it were me. My 2 cents.
Old 12-11-2017, 04:59 PM
Was a bit hard to find the 5 amp, but napa does carry them online. Will do just that.
Old 12-11-2017, 05:20 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Pack of 40 (10 of 5A, 8A, 16A and 25A for $12 with free delivery.
https://www.amazon.com/40-piece-Ceramic-Torpedo-Mercedes-Porsche/dp/B00KQHJDB4/ref=sr_1_1?ie=UTF8&qid=1513071902&sr=8-1&keywords=porsche+fuse
Who Will Live... Will See
Old 12-12-2017, 01:49 AM
Thank you JJ.
Old 12-12-2017, 04:29 PM
roadster49's Avatar
Just checked and they not available
Old 01-31-2018, 02:22 PM
JJ 911SC's Avatar
They were at the time I post it. If you are stuck, Im sure someone close by will help you.
Old 01-31-2018, 02:28 PM
