DAS-Sport System Rollbar?
Considering welding in one of these. Not ready for a full cage as the car is 90% street driven.
Pros? Cons? DAS Sport's phone # seems to be out of service. THAT can't be good.
I have the DAS "weekender" in my Targa. It is a bolt in roll bar. The fit was fine, and I have no real complaints about quality. Design wise, the top bar could have been set higher to be closer to the ceiling of the car/targa bar. As it is, the DAS bar cuts right across my line of sight out of the rear view mirror.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
They don't appear to have a working phone #. Out of business?
Moses,
There was a thread about this recently. Roll bar Someone mentioned that since the DAS uses existing holes, it doesn't add rigidity. I like it because it is easily reversable.
'08 RX350 (Hers) '84 911 Carrera '83 911SC Cabrio '06 Miata |
I have a DAS in my 993 it goes in easily, no new holes. Gives a nice solid place to tie off the harness. It is PCA club race approved.
The only negative is weight. You do realize that any decent bar will make the rear area unusable.
I had one in my Carrera and it was fine.
That being said, Dave B. makes a very nice one.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I have one in my SC and it is great. No holes to drill and the required removal of the rear seat backs helps to offset some of the added weight.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
FWIW....I'd get the TRE roll bar,that is if you're going to be welding anyways....
I doubt they are out of business. If the phone # on the DAS website doesn't work it may have been changed or just out of order.
If you have no luck there, then try CDOC , you can get the DAS rollbar thru them. I have a bolt-in one in my Carrera cab, fits great, no complaints. Good luck
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
MBruns for President
CDOC sells em
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
