Headlamp to fender seals split after only 6 weeks!
I installed both new rubber seals (from Pelican) betweeen the headlight ring and fender. 6 weeks later they have split! They felt cheap when I installed them, something like foam rubber. Is there a problem with the current supply? Maybe these are Chinese knock-offs? The previous set lasted 12 years!
Old 08-22-2006, 11:32 AM
dmwallace's Avatar
Same thing happened to the seals that I ordered a few months back from our host. I was thinking of gluing them back together with Goop (under the assumption that they all pulled apart).
Regards,
David.
1997 Carrera 993 coupe
- Slate Grey Metallic / Classic Grey
1989 Carrera 3.2L coupe - departed
- Stone Grey Metallic / Silk Grey
Old 08-22-2006, 02:06 PM
super glue, the world's worst glue, actually works real well on that rubber. just hold it until it sticks.
206 637 4071
Old 08-22-2006, 02:09 PM
dmwallace's Avatar
Good tip, John!
Thanks,
David.
Old 08-22-2006, 02:11 PM
ruf-porsche's Avatar
Re: Headlamp to fender seals split after only 6 weeks!
Why do the "CHINESE" always get the bad rap for poor quality?
Maybe they're Mexican or Canadian Parts, or how about Indian?
Just don't buy those Cheap "Chinese" super glue knock off.
LOL
Old 08-22-2006, 03:46 PM
RFR RFR is offline
RFR's Avatar
Just after reading this post, the UPS man delivered a set.
Looking at a brand new one, it is obvious to me there is a glued seam.
I think they are glued instead of being molded in a circle.
BTW, which side is out??
RR
Old 08-22-2006, 04:13 PM
RFR RFR is offline
RFR's Avatar
Did you have problems installing the headlights also? I cannot get mine to compress enough to get the headlamp to seal.
RR
Old 08-23-2006, 01:41 PM
Re: Re: Headlamp to fender seals split after only 6 weeks!
Because they build a lot of crap.
Old 08-23-2006, 02:00 PM
I had the same problem, got mine from Performance Parts. Repaired with black silicon caulk. Lynn
lynn, 68 912 coupe, 2011 Cayman base
Old 08-23-2006, 02:12 PM
steve911's Avatar
I had the same experience with a set I bought here a few years ago. I called and was sent a new set to replace the defective ones. Haven't had a problem since.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 08-23-2006, 04:22 PM
RFR RFR is offline
RFR's Avatar
Pure crap. Mine split after a day, right at the seam where it was glued.
Besides that it is too thick I cannot get the H4 ring to hook on the top.
Old 08-23-2006, 05:30 PM
Now what? Does anybody have an idea where to get a quality headlight O-Ring?
Old 08-23-2006, 08:45 PM
RFR RFR is offline
RFR's Avatar
Perhaps this is all that is available anywhere. lord knows who manufactured it!
I do know this; it is one length of rubber that is glued together. Maybe John Walker's superglue trick is better than the glue used in manufacturing.
I would imagine that the original Porsche part was a continuous molded circle.
For me the problem still remains with the thickness.
Looking at pics in our host's tech section, it is clear to me that original or earlier manufactured rings are thinner.
Maybe it's time to bring out the exacto.
Roman
78 targa
Old 08-23-2006, 09:41 PM
Banned but not out, yet..
RSBob's Avatar
Bought 'genuine Porsche' and there has been no problem in 2 years. No disrespect to Wayne.
Old 08-23-2006, 09:52 PM
scottb's Avatar
Check out THIS THREAD. From the sound of it, the cement being discussed is a very agressive form of rubberized super glue and will do the job.
Good luck.
1984 Targa
Old 08-23-2006, 10:06 PM
Those things have been that way for decades, from what I can remember. I don't even give it a second thought. Go to Lowes, H.D. or some similar place & buy a roll of thin foam strip insulation & make your own.
Marv Evans
'69 911E
Old 08-23-2006, 10:11 PM
RFR RFR is offline
RFR's Avatar
ScottB, I want to thank you for taking the time to find that thread!
you are either bored out of your mind or dedicated :-)
Old 08-23-2006, 10:44 PM
mine came from the Porsche dealer and have the same problem so i don,t think it,s a Perlican Parts only problem. Used some biketire repair glue (??) to fix them works great.
87 Carrera Backdate
Old 08-23-2006, 11:21 PM
WOLVERINE's Avatar
please add me to the list....after 3 months,yesterday driving to work and notice something flapping in the air.....take a guess...purchased at PP.
1977 Porsche 911S (Widebody)
Old 08-23-2006, 11:26 PM
Carl83911's Avatar
Got them from a bad batch?
I replaced mine a little over a year ago when I upgraded to the H4s and mine feel like rubber not foamy like you describe.
Carl,
Old 08-23-2006, 11:30 PM
