Guest
Posts: n/a
mechanical injection pump timing
To set up a stock MFI, one sets the end of the pump injection stroke to 40 deg. overlap TDC/CYL1. this is true for all stock cam profiles, correct?
Bruce |
Guest
Posts: n/a
There's a 'FE' mark on the MFI engine crank pulley to align the injection pump timing with ... Haynes manual shows the procedure and the timing marks.
------------------ Warren Hall 1973 911S Targa |
