Eric Coffey's Avatar
Originally posted by rsa
Maybe the only additional down force needed would be winglets on the bumpers. They can be adjusted to size and angle of attack at the track according to environment that day.
+1
For front end aero treatments, you might try experimenting with different winglet configurations ala DTM/LMP cars. Here are a few examples to offer inspiration:
Old 09-09-2006, 05:23 PM
Wer bremst verliert
JohnJL's Avatar
I'm in "day 2" of construction...here are my notes so far:
I'm using a little heavier gauge alu for the ribs...1.6MM. I alternated the tabs. I clamped all 7 ribs together and ised a jigsaw to cut all the tabs and beam slots identically.
I am using "U" shaped extrusions for the top and bottom braces. When I brace them together I am thinking I'll get some additional torsional rigidity.
I've got 2 of the ribs done up...another 5 to go...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-09-2006, 05:50 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
So Jack are you looking to make a career change?
Writing isn't enough, so you're becoming a fabricator?
Great wing! I hope it worked out well for you at the track!
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 09-09-2006, 08:09 PM
wesayso's Avatar
Originally posted by Jack Olsen
I'll post here with my subjective driving impressions (and/or reports of the wing's spectacular and catastrophic disintegration ).
So how did the wing do? Did it stay in one piece (actualy two pieces )?
'82 911 SC
Old 09-12-2006, 02:30 PM
Administrator
Jack Olsen's Avatar
I'm working on a longer write-up while I wait for pictures in the mail. But the short answer is that the wing worked great, and held up to the stress without problems. The base distorted and compressed a little (which hadn't happened with 250 pounds of sand -- which means the thing was doing some serious work). But I reinforced the base after a quick Home Depot visit, and it worked well the rest of the weekend.
Old 09-12-2006, 04:21 PM
Wer bremst verliert
JohnJL's Avatar
Awesome Jack! I have the entire internals done and braced now and will start on the skin this weekend.
Did you get any distortion around the skin where it mounts to the ribs? I thought I'd get a smoother, more consistant shape and have more surface area to bond the skin if I first ran a strip of sheeting around each rib (and possibly add a rivet or two in addition to the bonding) before mounting the final external skin. What do you think?
Old 09-13-2006, 01:53 PM
Wer bremst verliert
JohnJL's Avatar
Oh, and any lap time conparisons?
Old 09-13-2006, 01:54 PM
Administrator
Jack Olsen's Avatar
I didn't add anything in between the ribs and the skin, with the exception of the anchor pieces (the ribs with the 'feet' that mount to the uprights), where I added a piece to keep the piece from cutting through the skin like a knife.
I found that I got a less consitent shape when I tried alternating the tabs (when I built my second wing). If you've got a similar situation, then adhering a strip that's a little wider than the width of the spread tabs might make a smoother surface.
How about some pictures? I'm curious to see how someone else would do a project I jumped into with so little experience.
I thought about them, but couldn't come up with a way to mount them without putting holes in visible places on the car.
Old 09-13-2006, 08:48 PM
Administrator
Jack Olsen's Avatar
The splitter and the wing -- with a very trusting passenger:
Here's a report on the day, with good news and bad.
The bad:
- I left my camera bag at home by accident. I'd wanted to shoot footage of the wing at speed in order to see evidence of vibration or stress and where it was located. I had the camera set up to shoot straight ahead, but the one that would have shot the wing itself was home on the kitchen table. As a result, I don't have footage of the wing at work.
- Based on my initial 250# sandbag tests, I changed the rear mounting piece where the upright attaches to the tail. My new piece was thinner, but it had better lateral support. I tested it twice in a straight line with no one around me up to 135 mph twice, and everything looked fine. But on the first session out, the new pieces (which had a bend in them to keep the uprights parallel) started to bend further and flex down, in spite of a horizontal support between them that was supposed to keep that from happening. I spotted this after the first session and added some extra long bolt bridges to further triangulate the areas under stress. It worked all right, but I also damaged the wing while doing the repair -- I twisted the wing to move the uprights over for space to drill, and the short rear connector tube tore loose from its rib.
The track photographer got some pictures when I was giving Pelicanite bynbad914 (Tim) a ride. There's some interesting stuff in the pictures, where the speeds are about 120 mph.
In the first picture, you can see some burping distortion in the fiberglass hood. You can also see where the unsupported corner sections of the splitter appear to be bending down. You can also see the joining point in the center of the wing, where the part I damaged is causing uneven mating surfaces. (It's easier to see in a higher-resolution version of the photograph.)
In the second, slightly faster picture, you can see the front splitter bending down between the supports that run up to the bumper. You can also see the problems caused by the flexing base pieces below the uprights. The wing wasn't being held up equally on both sides, so it's twisting, slightly, in this picture.
At the end of the first day, I went to the local Home Depot and got the hardware to make spacers to simply replace the point where the metal bent. I also got some JB Weld to fix (somewhat) the damaged rear connecting tubes so the two halves of the wing would mate more evenly.
It was after dinner when I got the time to do the repairs, so I took the parts inside. I've never hammered and drilled in a hotel room before, and I was a little worried that I was going to get complaints from the neighbors. My approach was to turn on some TV programming (a Korean talent show) and the shower at the same time, and just hope that I was creating enough of a distraction to drill two quick holes and flatten out some steel. It only took a couple of minutes, but I felt like I was in a breaking-out-of-prison movie where I was going to be caught at any point.
The new base was heavier, but it held up fine all day on Sunday. Unfortunately, I don't have any high-speed pictures from the second day.
In any case, I'm seeing what parts of the wing and assembly should be made more sturdy in iteration 1.1 of the wing.
The good:
The wing itself showed no sign of stress, and I couldn't hear or feel any evidence of flutter at speed on the freeway or the track. From what I can see so far, it held up fine. When I do build version 1.1, I'll do an 'autopsy' on this one. But from everything I can see, it is plenty strong enough -- at least before time and fatigue start to reveal themselves. There were gusty wind warnings for Saturday afternoon, and there were still no signs of trouble with the wing.
Running without the wing, my best time was a 1:33.4. Running with the wing, my best time was a 1:30.4. The difference in driving was very noticeable. I'll see more clearly when I look at sector times in the data logger, but the comfort level through turn 1 (a 90-degree left), turn 2 (a 95-mph sweeper) and turn 8 (a 130-mph sweeper) were immediately noticeable from the first time I went out. With the wing, I was carrying about 200 more rpms through turn 2, flat on the gas through the entry and the exit, with far fewer corrections. In turn 8, where I wasn't brave enough to study the tach, the car was so well planted that I could go through it flat even on the first lap of a session when the tires weren't up to temp.
My top speed during a lap with the wing was 129.62. My top speed during a lap with the ducktail was 130.79. Both times were at the end of the front straight. This may not mark the full extent of the price of the additional drag, though, since I was probably entering the straight with more speed with the big wing, but still reaching a lower top speed before the braking zone for turn 1. When I go through the data, I'll try and pick a fixed exit point for turn 9 and see what the difference is from the finish speed in both configurations.
It's interesting to compare these times to the last time I was at Willow with the shorter wing. On the same tires and at the same track, the best I could do then was a 1:37 with no aero and a 1:33 with the wing and splitter. The tires I'm running are a full size down from my normal sizes. But they're Toyo Proxes RA1's, which have a long lifespan and should be good for this kind of testing. However, they're known to continue to get better as they heat cycle, which is part of the explanation for the improved times. I was also able to run race gas this time, which allows me to run a different programming map for my car's computer (I have a switch and a 'two chips in one' No Bad Days chip). Track surface conditions and driver inconsistency are also factors, I'm sure.
It's certainly all within my testing's margin of error, but there was a 4-second difference previously, and only a 3-second difference this time. Now, that could easily be misleading, since the track loses 1-2 seconds during the day because of accumulated heat and coolant/oil/tire rubber. But it could be that with my limited power that I've reached a point of diminishing returns with drag and downforce at the new wing size. It makes me want to test multiple wing sizes on the same day -- maybe make a 60-inch one, next, or another 70-inch wing but with a reduced chord length.
In terms of F/R balance, the car felt great, although there was some push to it. I'm thinking as a next step that the front splitter stays the same and maybe the wing gets reduced in size.
I also did some looking underneath cars and diffuser designs. There were two of the new Ford GT's at the event, but I didn't get a chance to look at their underbody stuff at all. I looked at some of the Vipers and the new Corvettes, but the most complete-looking package was on the Lotus Exige. I took some measurements with it of the height at the front axle down to the point where it changes its angle, about a foot ahead of the rear axle, and then where it angles up to the diffuser. One of these days, I'm going to take another stab at some underbody pieces.
One more picture:
It almost looks like the wing is doing too good a job there, doesn't it?
Old 09-13-2006, 09:24 PM
Zeke's Avatar
Well, to come right out of the box and make an improvement on an already proven wing is just outstanding! Things can only get better from this point forward at Olsen's WingWerks. You know what they say, Jack's just wingin' it.
Old 09-13-2006, 10:03 PM
Don Plumley's Avatar
Impressive work, Orville. Now get back in the shop and fix some bicycles.
Don Plumley
M235i
Old 09-13-2006, 10:22 PM
In all sincerity, it was quite a ride! Wow!
Don Plumley
M235i
Old 09-13-2006, 10:36 PM
Wer bremst verliert
JohnJL's Avatar
Continuing to amaze, Jack.
...but you do know how to deflate a guy! Actually you nailed it....I've successfully built a house, rebuilt a motorcycle, built a rock-crawler and launched a brokerage software company without prior experience or schooling in any of those. I believe I posess a unique mix of stupidity (didn't know it was that hard), humility (I ask lots of questions) patience and outstanding luck. And great, generous friends.
Notice I didn't list "successfully build a 911 race car." Its still a work in progress and with it in the suspension and paint shop, I'm crawling the walls. I need a project to work on and your writeup had impeccible timing!
I would post pics but I sacrificed it for some poontang. By that I mean I brought it to a wedding and got so blitzed and distracted by a bridesmaid that I left the camera. But I did score the bridesmaid. God I love being single again.
I will post pics soon. I think I will go ahead and run a layer of sheet alu around the ribs. It seems beyond my ability (patience) to be able to determine if all the rib "flaps" are parallel/square. My hypothesis is that with a strip around it I can use a level, string and square to get all the ribs uniform.
Thanks for posting the data. My 1.0 design is 60 inches since mine is a narrowbody and I need to stay within the width of the car. I haven't weighed it yet...I will likely outweigh your though due to some additional (possibly unnecessary by your experience!) bracing. Then again mine is 1-piece so maybe we'll be close...
Old 09-14-2006, 03:56 AM
Jack, if youre getting some aero push why wouldn't you stiffen the rear bar vs make the wing smaller. If I set my 911 neutral on the lower speed stuff its too tailhappy in the highspeed sweepers, or neutraul at high speed = push at low speed. A turbo tail helped but I haven't had a changce to try the 3.8RS wing (or a big high mount) yet. I always though the idea of aero was to be able to tune the high vs low speed settings differently (sort of like multi-way adjustable shocks w/ high and lo-speed rebound).
SMD
Stephen
70 914/6, GT clone, 3.0L
83 911SC, IROC clone, 3.32L, EFI
84 930, 3.5L
Old 09-14-2006, 07:07 AM
Zeke's Avatar
I'm not leaving the monitor until you do.........
Old 09-14-2006, 09:52 AM
Wer bremst verliert
JohnJL's Avatar
Ha, That would be posted "Off Topic." She too was tail-happy. Or is that me?
Old 09-14-2006, 02:24 PM
byndbad914's Avatar
You know Jack, people have set up complete meth labs in hotels, so I doubt some drilling would have been noticed Anyway, do you have any shots of the final mounting scheme with the spacers? Just interested to see how that all turned out.
BTW, I rode with Jack back in January when I had my car at the track and can say that his car is flying thru Turn 2 now by comparison. The car felt much better to me through there at least... and I think faster thru T8 as well. I really can't even begin to imagine how some of those cars turn 1:22-1:24s on that track.
Tim
www.negativereinforcementracing.com
1972 914 1.7L turned FW190-V8
353cube 525HP SBC with Mendeola S4 transaxle
Old 09-14-2006, 06:25 PM
Wer bremst verliert
JohnJL's Avatar
Zach, no bridesmade pics but some other progress...
here's a series from the construction...
i added a base layer over the ribs for added surface layer/structural rigidity in the hopes of adding strength and saving some weight. But it certainly isnt as trick as Jack's 2-piecer.
I used some rivets and aluminum-powder bonding material. Here I am using levels to check parallel and eliminate compounding error with the additional bonding layer.
Old 10-16-2006, 05:45 AM
Wer bremst verliert
JohnJL's Avatar
Sum more....
the last one is of what its going to replace...duck to come...
Jack is a master, thanks for the inspiration!
Old 10-16-2006, 05:56 AM
Administrator
Jack Olsen's Avatar
Looks good. The U-shaped spar pieces will resist twist better than my T-shaped pieces.
It looks like yours is going to be a single piece? What's the total wing width/chord length and rib spacing?
Old 10-16-2006, 11:06 AM
