Turn Signal / Flasher Problem (PIX)
Today I was reinstalling my center console and after hooking up the switches my emergency flasher did not work but the switch light burns solid red when depressed??? Then I checked my turn signal and they dont work either??? Now I know hooked them up properly - theres only one way the hazard switch plugs in. What could I have done?
Is there a chance I did something and fried my relay? Does this sound like a relay issue? Thanks as always!
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) Last edited by Super_Dave_D; 09-01-2006 at 08:07 PM.. |
If the flasher relay is okay it could be a bad ground. You can run a ground to the switch with a jumper wire to check.
69 911 2.3Ez 85 928S |
Is this my flasher relay location? I couldnt find a pic here. If it is - looks like this is part of my issue because the the relay in mine is 3 prong and its supposed to be 4 prong??? The PO must have been too cheap!! Strange how the signals worked but I never tried the 4 way so I dont know.
Got a good deal ($199) on a carpet kit and so far I'm over $2000 and now this!!!! So I'm a little frustrated!
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
Yes, you need a four prong flasher. You may be able to get one at a local auto parts store. Just make sure the pins are wired for the car. Look at your electrical diagram and take a pin diagram to the store. You need the pins of the flasher to match the socket. This should fix the problem. Or call Pelican. They have them too. Good luck.
bump
