turbo2.0
Guest
Posts: n/a
911S caliper I.D. help
I have an opportunity to buy a set of 911 calipers for very little money. The seller says they are off a 77 911S, he thinks. Is there a way to i.d. these calipers? How dfo I figure out if they are S or T calipers?
TIA
Gerald Gore II
Old 05-07-2000, 01:24 PM
Early_S_Man
Guest
Posts: n/a
Those should be the cast-iron 'A' calipers, which have the same 'wide' spaced mounting ears as the 'S' calipers ... if they are made of cast iron and have center-to-center distance of 3.5" or 88 mm, then you have the 'A' calipers. If they are aluminum, then you lucked out and have the 'S' calipers!
Warren Hall
1973 911S Targa
Old 05-07-2000, 02:13 PM
