Guest
Posts: n/a
911S caliper I.D. help
I have an opportunity to buy a set of 911 calipers for very little money. The seller says they are off a 77 911S, he thinks. Is there a way to i.d. these calipers? How dfo I figure out if they are S or T calipers?
TIA ------------------ Gerald Gore II |
Guest
Posts: n/a
Those should be the cast-iron 'A' calipers, which have the same 'wide' spaced mounting ears as the 'S' calipers ... if they are made of cast iron and have center-to-center distance of 3.5" or 88 mm, then you have the 'A' calipers. If they are aluminum, then you lucked out and have the 'S' calipers!
------------------ Warren Hall 1973 911S Targa |
Thread Tools | |
Rate This Thread | |
