bonaturtle's Avatar
Send a message via ICQ to bonaturtle Send a message via AIM to bonaturtle Send a message via Yahoo to bonaturtle
Do we have 1 or 2 O2 sensors on an 88?...
my HC's were way too high at my emissions test, thinking I have a bad O2 sensor.
Sean
1988 911 Coupe Blk/Linen
1992 Mercedes-Benz 190 2.3
1999 Honda Accord LX
2003 Kymco People 50 (city killer)
Old 09-07-2006, 09:04 AM
Friend of Warren
You have one.
Kurt V
Old 09-07-2006, 09:05 AM
craigster59's Avatar
There is also an oxygen sensor relay that you should change while you're at it. Around $20
Old 09-07-2006, 09:08 AM
der Mond's Avatar
Why, is that a troublesome relay? Haven't heard of that particular problem...
Peace & Thanks,
der Mond
'87 Carrera Coupe
Venetian Blue Metallic
Old 09-07-2006, 09:22 AM
bonaturtle's Avatar
ah, yeah, found it. gotta find something else to order with it, seeing i can get a sensor elsewhere for cheaper.
Sean
Old 09-07-2006, 09:37 AM
I'm going thru the same thing, high HC's. It's another link in the chain to solving the problem and as long as you're ordering parts the cost ( $20 is high, they can be had for 10-16 dollars) saves a second trip/phonecall if the sensor doesn't solve the problem.
Old 09-07-2006, 10:35 AM
Relay for an oxygen sensor on an 88????? huh
That coax is supposed to go directly to the DME.
The heater for the OXS is an un-fused lead off the DME relay that also powers the fuel pump. It should be easy to tell if that is working.
Old 09-07-2006, 11:35 AM
