Chris_1983's Avatar
So, where does this belong?
I have a 1983 911 SC and the truck light does not work. Upon inspection I found this little guy just hang'in there. New car for me and trying to figure my way around.
Thanks for all the help with the fuel pump noise!
Old 09-06-2006, 04:27 PM
I'm with Bill
Rick V's Avatar
Well being brown I would suspect it is a ground. From the looks of the wire sticking out of the housing it looks like it pulled out of a conector.Start looking around for a round terminal that is bolted to the body in that area. I will look in my 82 and see if I can find it in my car.
Old 09-06-2006, 05:01 PM
I'm with Bill
Rick V's Avatar
There is a group of ground wires right there next to one of the air vent tubes. See if one of the wires is ripped out from there.
Old 09-06-2006, 05:04 PM
Chris_1983's Avatar
Okay, found the white round connector near the hose. It appears to be a 6 wire connector, but in mine only 5 wires are being used. This is on both sides. In other words, I have 5 wires coming in and going out the other side. With 1 empty connector position on each side.
Old 09-06-2006, 06:48 PM
