Somatic Negative Optimist
AAR - Auxillary Air Regulator
AAV - Auxillary Air Valve WUR - Warm Up Regulator (Also called Control Pressure Regulator) CSV - Cold Start Valve FD - Fuel Distributor CIS - Continuous Injection System CDI - Capacitance Discharge Ignition You also have a deceleration valve, throttle switch, air flow sensor switch, frequency valve, acceleration enrichment control unit, Lambda Emission Control, and a pile more sensors on your engine. Shocking, isn't it? Get the Bentley SC Repair Manual, you'll love it. It explains how these components function.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Find yourself a mentor on this forum. List your location. I'm sure a fellow Pelican can help you.
It's impressive and shocking...thanks guys for taking the time!
Counterclockwise?
Let's not forget about the ICV (Idle control valve)
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
He has an SC with CIS, not a Carrera with DME.
Counterclockwise?
I posted this because a few Carrera guys have chimed in with the same problem. I should have been more specific. I'll be taking my 86 Carrera in for a CO check etc to Tuesday and will keep everyone posted. Thanks Rod
