What did I remove?
I removed a plug similar to the sump plug, thinking it was the sump plug. Oil came out and so did a 4 inch spring. It is unclear if anything else came out. Doh@!
Thermostat?
_______________________ Unless you change your course, you are likely to end up where you are headed. '87 Carrera, Black on Black |
Oil pressure relief valve. I did the same thing. There should be more parts than just a spring. Oil plug is on the side of the lower case...instead of the bottom.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Hope this helps.
You may want to check your drain pan for the piston in this pic???
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks you guys!
I found the end, but I am missing the piston. Probably down the drain of the oil pan or shot out somewher in the driveway. I will look for it in the am. I appreciate the illustrations/pics. Matt
