Serial number question
I was cleaning my truck when I noticed the serial number, knowing my serial number by heart, I knew something can not be right
In the trunk it reads : WPOZZZ91ZKS171082 and in the door panel: WP0EB091XKS171082 The car is registered with the door panel number. Any Ideas ? I'm starting to get a little worried, I am the second owner and I know the first owner never had an accident.
According to the Parts an Technical Manual,"All chassis are stamped with ZZZ.However,the VDS code will be different on the VIN tag or on the title."
Don't know if this helps.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. Last edited by rs6er; 09-09-2006 at 05:25 PM.. |
Old Member
email sent.
Clifton Brown https://www.mancalamarketing.com |
This is the area around the vin stamping.
