Reverse light question.
Anyone has any pics of the reverse light switch on the tranny? I want to know where to look for it.
How about fuse/relay. Which fuse/relay should I look for? Thanks.
Fat butt 911, 1987 |
Bird. It's the word...
It varies depending on the g/b. 901 is on the side, 915 is on the end near the shift rod, but I presume you have a G50? Dunno about those, sorry.
John Forcier Current: 68L 2.0 Hotrod - build underway |
Yes I have a G50
Thanks.
with your head at the shift linkage looking up go to the left and you should have a 2 wire plug attached to the end of it.....FM
So it should be on the US driver side and proxiamtely the middle section of the tranny?
more to the pass. side kinda hidden from the tranny brkt....FM
THanks. I'll try to look more carefull
I think I found it. It look like it's on the right of the tranny with 2 wire. The switch is small and is threaded into the tranny. I always thought it is for the speedometer.
If it is the reverse light, then which one is for the speedometer? Thanks.
Fat butt 911, 1987 Last edited by rnln; 09-18-2006 at 09:43 PM.. |
