rnln's Avatar
Reverse light question.
Anyone has any pics of the reverse light switch on the tranny? I want to know where to look for it.
How about fuse/relay. Which fuse/relay should I look for?
Thanks.
Fat butt 911, 1987
Old 09-09-2006, 09:54 PM
Bird. It's the word...
Fishcop's Avatar
It varies depending on the g/b. 901 is on the side, 915 is on the end near the shift rod, but I presume you have a G50? Dunno about those, sorry.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 09-10-2006, 04:13 AM
rnln's Avatar
Yes I have a G50
Thanks.
Fat butt 911, 1987
Old 09-10-2006, 11:51 AM
rnln's Avatar
Fat butt 911, 1987
Old 09-11-2006, 11:58 PM
with your head at the shift linkage looking up go to the left and you should have a 2 wire plug attached to the end of it.....FM
Old 09-12-2006, 07:06 PM
rnln's Avatar
So it should be on the US driver side and proxiamtely the middle section of the tranny?
Fat butt 911, 1987
Old 09-12-2006, 07:21 PM
more to the pass. side kinda hidden from the tranny brkt....FM
Old 09-12-2006, 09:32 PM
rnln's Avatar
THanks. I'll try to look more carefull
Fat butt 911, 1987
Old 09-12-2006, 09:42 PM
rnln's Avatar
I think I found it. It look like it's on the right of the tranny with 2 wire. The switch is small and is threaded into the tranny. I always thought it is for the speedometer.
If it is the reverse light, then which one is for the speedometer?
Thanks.
Fat butt 911, 1987
Old 09-18-2006, 04:14 PM
