Mike the mechanic
Guest
Posts: n/a
Flashers stopped working
On my drive home from work today, my turn signals stopped working. My hazard lights work, no bulbs are burnt but when I flick the turn switch, nothing happens. Is there a separate relay for flashers? I can't check it out till tomorrow, it's raining hard outside.
Mike
Old 05-24-2000, 04:10 PM
Jens Wendorff
Guest
Posts: n/a
Should be the Relay. Its a combination for emergency and turn signals. Mine worked for the turns-not for the emergency.
On '76 onward cars, the relay is located just underneath the instruments. You get access from the luggage compartment.
Old 05-25-2000, 05:34 AM
Mike the mechanic
Guest
Posts: n/a
Thanks, although I finally checked it and it was a burnt fuse.
Mike
Old 05-25-2000, 04:50 PM
