Dry cams
I can hardly believe the saga of my friend's engine. It was seized from sitting. He broke it loose with Marvel Mystery Oil and patience. Then it wouldn't start because of an internal short in the distributor. Then it wouldn't run on al 6 because of stuck injectors and MFI pump.
One by one, these problems have been revealed and addressed, but now, with it running okay, the lower valve covers were dropped for a valve adjustment and it appears the cams aren't getting oil. Some lobes are dry. The cause isn't directly obvious, but a clue is that the lower valve covers were sealed with a lot of silicone. If silicone has broken loose and travelled the oil passages, is there any solution other than complete teardown?
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Rube Goldberg at your service.
How about a simple idea. Get a small pump-up bug sprayer from the local home supply and adapt the flex cam oil hose to it. With the valve covers off, pump up the sprayer with engine oil in it. See which cam oiling spray bar ports are blocked. Try getting whatever out with some fine wire while the oil is flowing. Or Is it too late and the cam is damaged? Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Grady,
Clever!! Doug
1971 RSR - interpretation |
The cams are not damaged. They haven't been run but for a few minutes in years.
Now in 993 land ...
You can suck on the cam line too, to get the silicone out of the cam oilers.
![]() George |
Now in 993 land ...
So, can someone elaborate how the silicone gets into the cam spray bar past the oil filter?
G |
Depends where the silicon is and where (else) it was used? If it comes from the valve covers then it could makes its way back in through the pressure relief system on the scavenge oil system. Seems unlikely. OR if it comes from somewhere else..... (as you know) oil is filtered on its way back into the oil tank after thermostat, not on the way into the inlet side of the pressure pump (fed by S-oil line). Doug
Now in 993 land ...
Good point. There may be more silicone. But if it is just on the valve cover, it's hard to see how it gets to the pressure side of the oiling system.
Techweenie, I am surprised that your pal did not just take the engine apart in the first place. I'd be scared to start such an engine without tearing it down. But I suppose he is trying his luck ? George |
