Slackerous Maximus
Antenna mast? Need help.
Uh oh.
My car (82 targa) is in the shop for some repair work. My antenna got broken off. The OEM part from Porsche does not match the one in the car. Evidently it has been replaced at some point in the past with an aftermarket unit. The antenna mast that was on the car has a white plastic cable with little 'teeth' on it for traction. Anyone know who makes it? Are there a limited number manufactures of aftermarket retractable antennas?
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Sultan of Sawzall
Sounds almost like a Hirschman antenna I had. Probably buy a universal replacement unit $40-50 if you wish (they have some units with VERY small motors that will fit just about anywhere. I've seen them for 1/2 that price on EvilBay
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) Last edited by rouxroux; 09-12-2006 at 11:22 AM.. |
1.367m later
Most power antenna use the same white platic toothed cable. Try using the mast from a later model unit. I just repaired a unit from a '77 that way.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
I just ordered a new mast from fcp groton off of ebay. You should call or email them directly to get the correct one though.
jt -84 targa |
Slackerous Maximus
Thank you guys. It was a Hirschmann unit. This saved me some serious time.
