Super Moderator
cstreit's Avatar
996 GT3 - Equal leakdown out of both exhaust valves?
Okay I'm stumped....
Getting low compression (obviously) and high leakdown out of my Cup engine. It's coming out of the exhaust.
Whats weird - is that it's coming out of both exhaust valves at the same time. As if the cam wasn't closing them properly. It's only on one cylinder. Why would both valves do this? They don't share a lifter, spring, etc...
Baffled.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-29-2016, 10:02 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Carbon build up? Have you removed your headers to see what the ports look like?
'85 Carrera Targa
PCA/POC
Old 10-29-2016, 10:18 AM
Super Moderator
cstreit's Avatar
Yes. Valves look nice. Most likely that they are both bent I guess.
Purely a race engine run on 100 Octane- so carbon is minimal.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-29-2016, 10:19 AM
DRACO A5OG's Avatar
Damn, bent valves, what a nightmare :-( Sorry to read that brother.
'85 Carrera Targa
PCA/POC
Old 10-29-2016, 10:23 AM
What are your leakdown values????
Bent valves not uncommon, especially if you missed a shift.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-29-2016, 12:46 PM
Walt Fricke's Avatar
A missed shift overrev in the engine's history? Is the fact that it is only one cylinder with this leakage the good news part of this good news/bad news story?
I gather that the reason you know both exhausts on that cylinder are leaking is that you pulled the header? Can't see how you could know it was both otherwise.
Old 10-29-2016, 05:04 PM
It is extremely rare to bend valves on the GT3 engines. The valves are very lightweight being small and titanium
Is it a solid lifter motor or has it been converted to hydraulic? The mechanical cam followers wear the
cam carrier and can get hung up
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-29-2016, 06:15 PM
Super Moderator
cstreit's Avatar
I'm pulling the engine for a refresh because it's got 80 hours on it. I did the leak down with the headers off. Even sprayed soapy water on the valves to watch. It's definitely both valves but only cylinder 2.
Overrev? Definitely. Several in fact so this is the most likely cause. When I wrote it it didn't occur to me that both valves would bend, but of course this makes sense.
Old 10-29-2016, 06:54 PM
Solid lifters or stock hydraulics?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-29-2016, 07:01 PM
Super Moderator
cstreit's Avatar
Stock GT3 Cup legal engine.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 10-29-2016, 09:08 PM
in mid 2001 Porsche changed from mechanical cam followers to hydraulic
many other parts were changed Cam carriers, rod length, crankshaft etc
Many of the parts for the early engine are no longer available
Cam carrier lifter bore wear was an issue on the earlier engine
Hope you have the later one
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-30-2016, 08:14 PM
