Neatrix Install Question
How much force should I expect to apply when installilng Neatrix bushings. Is it customary to use a hammer with a wooden block in between? The OD is generously greased. Thanks.
Walt 82SC 3.0 81SC 3.6 |
UFLYICU
Use long bolts to press it in with the t-bar cover plate. Work around slowly, and it'll pop right in. I used silicon spray on the outside of the bushing, and inside the seat.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
