Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
More front camber tricks?
I'm working on the front end of the 912-6 while I have the shocks out this week, trying to get more camber.
Anyone have any good tricks to get more camber, that don't involve $350 for ball joints or $450 for new camber plates?
I've pulled the stock plates and dug out all the black sealant. I was wondering what would be the affects of grinding off the wall of the camber plate, looks like I could gain another 1/8" at the top where it contacts the side of the housing. Maybe I could also massage the panel in that area to allow the plate to move inward a hair more.
Suggestions?
Thanks!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 08-15-2006, 07:26 PM
jaydubya's Avatar
The idea of grinding the edge of the plate seems like a good one. Are you sure there is more adjustment room?
I wonder if smaller diameter bolts would buy you anything?
'82 911SC racecar
'05 WRX STi
Old 08-15-2006, 07:41 PM
"The idea of grinding the edge of the plate seems like a good one."
... and often done. However, there's a physical limit of the material you can remove before the strut bumps up against the inner fender. Make it clean and don't forget to seal the bare metal.
Sherwood
Old 08-15-2006, 08:37 PM
instead of a grinder we used a band saw....
don't forget to remove the top strut watershield with that.
-2.8 degrees on ours with the above mods and a little bit of attention to the bolt holes.
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-15-2006, 08:46 PM
jaydubya's Avatar
Not sure what you mean by top strut watershield?
Thanks,
Jeff
'82 911SC racecar
'05 WRX STi
Old 08-16-2006, 06:02 AM
Stahlwerks.com
jhelgesen's Avatar
The water shield is the can that goes on top of the strut.
Maybe I can find a rubber bellows to seal it up, keep crap off the strut shaft?
John Helgesen
Old 08-16-2006, 06:33 AM
jaydubya's Avatar
^^^ Oh, the dust cover. Yeah, I would definitely want to put something there in its place.
'82 911SC racecar
'05 WRX STi
Old 08-16-2006, 06:35 AM
Stahlwerks.com
jhelgesen's Avatar
This was easy to find, and matches the bilsteins....
John Helgesen
Old 08-16-2006, 07:28 AM
jhelgesen,
Where did you get those? Txs
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 08-16-2006, 07:56 AM
Stahlwerks.com
jhelgesen's Avatar
Summit racing - search under shock boots, $6 a pair.
www.summitracing.com
John Helgesen
Old 08-16-2006, 08:12 AM
Stahlwerks.com
jhelgesen's Avatar
brant
Brant, any issues with tires rubbing the inner fender wall at -2.8?
John Helgesen
Old 08-16-2006, 08:14 AM
I haven't had any issues.
I'm running 22front torsion bars and low profile kumhos...
so it could be different on a street car set up.
I run 225's so I do get tire rub at full lock, but not due to camber.
Last night we re-did the alignment and the new figure actually came out to -3 degrees now.
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-16-2006, 11:57 AM
Stahlwerks.com
jhelgesen's Avatar
5 minutes with a band saw....
Before:
After:
Now I just have to open the holes in the chassis a bit to allow the strut mount to move inward more. Can't wait to get my shocks back now.....
John Helgesen
Old 08-16-2006, 06:14 PM
thats exactly how mine looked...
now get rid of that rubber and put some metal tops in there!
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-16-2006, 08:03 PM
Stahlwerks.com
jhelgesen's Avatar
Thanks Brant....give me some time on the metal mounts, my racing budget only goes so far.....hehehehe
John Helgesen
Old 08-17-2006, 04:02 AM
Brant,
Are there any drawback from not running the dust covers?
I am plaaning on doing this mod tomorrow.
Mario
'15 GT3
Old 09-16-2006, 06:08 PM
Brant,
Are there any drawback from not running the calipers? Unsprung weight?
Sherwood
Old 09-16-2006, 10:17 PM
i am doing this work rigth now and I need some advice.
Do I have to grind also the large hole on the chasis, where the strut support goes... or just the holes for the adjusting screws?
I already grinded the holes for the adjusting screws but it seems that the space gain is only marginal, since the camber plate will touch the chasis on the midle large hole.
I assume I could gain additional negative camber by grinding the large hole, but I am afraid of weaking the support for the strut.
Any advice will be greatly appreciated.
Mario
'15 GT3
Old 09-17-2006, 12:40 PM
