Mark Davis's Avatar
A/C & Power seat Problems
I have a 1985 911 and the A/C blower and the power seats stopped working. I have check the fuses and they are fine I have replaced the relay in the smugglers box. Any ideas on what else I can check.
Mark
Old 09-19-2006, 04:02 PM
The AC Switch and the Seat Switch check under the seat first and check power.
Old 09-19-2006, 04:43 PM
kuehl's Avatar
Re: A/C & Power seat Problems
Mark
Mark,
Let's leave out the seat for the moment, they just add weight to the car.
On the evaporator blower you can test the circuit front to back or visaversa: here is a hyperlink in PP that will guide you:
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_AC.jpg
I won't say this schematic is 100% but it is helpful.
Hint: start at the fan (direct power 12vdc off the battery with a jumper to the red/white spade terminal in the plug)
Old 09-19-2006, 07:05 PM
Mark Davis's Avatar
Re: Re: A/C & Power seat Problems
Originally posted by kuehl
Mark,
Kuehl
Thanks for the infomation I was able to jump it and the fan works. It turns out that the PO had run a new power wire for this and it had a burt out inline fuse.
Thanks for the help
Mark
Old 09-23-2006, 03:30 PM
