<insert witty title here>
Christien's Avatar
Caliper problem?
I was replacing brake pads and found this. Should I be concerned about this torn rubber around the piston? Could this be responsible for my soft brakes? (after multiple bleeds, no air to be found in the lines, and a relatively new (1 yr) master cylinder):
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-20-2006, 08:03 PM
That is the caliper piston dust boot.
It may not be responsible for a soft pedal but i would fix it straight away.
Over time, dirt & grit will get on to your piston and destroy the seal and maybe the piston as well.
Doesn't look like a fluid leak.
Keep looking at other wheels.
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 09-20-2006, 08:18 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
If you don't replace the dust boot, you will get rust on your piston and cylinder and may end up having to replace the caliper. Buy a rebuild kit. If you only replace the dust boot, it will take you 5 minutes and you won't have to remove the caliper.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-20-2006, 08:57 PM
Early_S_Man's Avatar
Porsche Crest
That 'S' caliper needs to be rebuilt and cleaned! The tear seems to be fairly recent, so I don't expect any problems with the rebuild.
Get 4 rebuild kits, new flex lines, and a tube of Dow Corning 111 Silicone Grease ... the whole system needs to be done at the same time!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-21-2006, 02:26 AM
Christien's Avatar
Ok, thanks guys. Looks like I have another winter project! May as well rebuild rather than just replace the dust boot, and I may as well do all 4.
Old 09-21-2006, 05:14 AM
