rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
AC Delete. What's left? Yes, I searched.
Finally bit the bullet and yanked the AC today, everything except what's in the smuggler's box and passenger floorboard. I want to keep the fan in the smuggler's box. What else do I need to take out?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-23-2006, 07:36 PM
Eric-325I's Avatar
Have you removed the front condensor and the bar that guards it? Also the small fan in the nose of the trunk (although it will leave a hole to cover with aluminum plate or whatever)? Also the hoses... Most people, including myself, recommend just cutting and pulling them...
Maybe you should tell us what you have removed so far.
Eric
'79 SC Silver over Black... Sold
Old 09-23-2006, 10:26 PM
rs6er's Avatar
I have removed both condensers, front condenser fan, drier, compressor and brackets, all lines cut at front undertray and removed. All I have left are the remainder of the lines leading to the smugglers box. I want to retain the fan to the dash vents and remove everything else from the smugglers box (evaporator etc,) I'd love to see a pic of the box with everything removed except what will supply air to the dash with the AC fan switch in the console. Also, what do I memove from behind the passenger floorboard? How do I remove the outside crankshaft pully that was used for the compressor belt?
John
Old 09-24-2006, 06:15 AM
fresh air i believe is supplied by that contraption up behind the dash by the wiper motor with air from the grill at the base of the windshield and not really affected by that condensor thingy (technical name) in the smugglers box - but i could be wrong. it has been a while since i had any of that stuff in my car.
a little of this + a little of that
Old 09-24-2006, 07:51 AM
rs6er's Avatar
I got everything out of the smugglers box. I removed the evaporator and am going to put the fan inside the plastic box back into the car. Hopefully that will supply more air on humid days.
John
Old 09-24-2006, 09:58 AM
Tired Member
DaddyGlenn's Avatar
There is a thermostat behind the passenger floor board. that is the A/C intake. Air is drawn in there and is then routed through the smuggler's box. From there it is pushed to the center dash vents, a vent under the dash and two small vents on the far sides of the dash.
Why are you yanking the A/C?
Glenn
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 09-24-2006, 10:35 AM
rs6er's Avatar
It hasn't worked in years and it really messes up working in the engine compartment. It's my hobby car. (I'll only drive it where there's no traffic unless I get stuck coming back from Lime Rock on July 4th.)
John
Old 09-24-2006, 01:58 PM
can't you remove the evaporator fan and re-route the ducting with the fresh air blower to use those dash vents?
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 09-24-2006, 02:07 PM
rs6er's Avatar
If I did that I dont think the defroster would work. Am I wrong? Also, the evap blower is 3-speed and pretty strong. It's all hooke3d up. When I finish a few other thinds I'll givie it a try.
John
Old 09-24-2006, 03:52 PM
OffCamber00's Avatar
You are wrong - sorta What you do is re-route the fresh air from the side vents to the center vent (previously AC only). You lose the ability to have heated air come out of the side vents, but for me that was no big deal since I really only need heat for the defrost and heat for my feet. This configuration also preserves the speed settings for the fresh air so you aren't losing anything there either. I have had things setup this way for a while now and it works great.
This frees up the smugglers box for a lightweight battery.
Mat P
1988 911 Carrera
Old 09-24-2006, 05:33 PM
rs6er's Avatar
Thanks Mat. I'll take a look at that.
John
Old 09-24-2006, 05:46 PM
Matt.
I take it you backdated the heat?
If you did, I would appreciate advice about exactly what parts are needed>
Thanks.
I PM'd you as well
cheers,
Phil
Old 09-24-2006, 06:16 PM
