azporsche911.com
Tranny mount bolt hole stripped...help!
I’ve owned the car for a year now, and just noticed while under the car one of the 2 Bolts is missing in the Tranny mount. So I go down to the local auto parts store and find the proper metric bolt, I return home and attempt to put it in and notice it isn’t getting tight. Took the bolt out and noticed some thread shavings. Looks like the PO or a mechanic stripped it out. AARG!
It looks like the tranny mount has to come off or drop the engine to re-tap it. Or is there another way to repair this? I'm just upset a mounting hole is stripped out that’s part of the chassis and im kind of intimidated by re-taping things. Yes i know.....NEWB! lol TIA -Jeff
Jeff Hoffman (Son) Tom Hoffman (Father) 79 911sc ROW guards red coupe father son project. |
Back in New England!
I'm sorry to hear that. You've got to love mechanics with pneumatic tools...
Depending on how bad that current hole is stripped, one way to fix it (and still use the original bolt) is to buy a hella coil kit. I've used them in the past and have always had a good experience with them. Very simple to install. Not as good as the original, but a close second. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Autodidactic user
Here's a good article that should help:
Repair of Damaged Internal Threads. Timeserts are stronger (and more expensive) than Heli-Coils. Although either will work for this application, using Timeserts will probably allow you to sleep better at night. Here is an article about using a Timesert for spark plug thread repair that might help.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
Irrationally exuberant
I've come across a few (3-4?) cars with the same issue.
To fix: Support the transmission with a jack stand Unbolt the transmission crossmember and remove it from the transmission. Timesert the hole (12x1.5 I think). Clean up the old transmission bolts or replace if too munged. Tip: When installing the transmission bolts, loosen the 4 crossmember nuts (M8 studs with "13mm" nuts) so the crossmember is free to move around while you get the transmission bolts threaded. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
azporsche911.com
Thanks alot guys, Great info and tips. I wasnt to sure on doing a heli-coil, so i will look in to a timeserts.
Thanks again, -Jeff
