Performing Compression Test
I've got my 2.7 engine removed from 1975 P car.
Can a compression test be carried out with the engine removed from the car?
1975 911 3.0 Carrera (964 Lookalike Weekender)
1975 911 2.7 (Project)
1979 Ford RS2000
1980 Mini 1275GT
1998 BMW 320i (Daily driver/Reliable Work Horse)
Old 09-25-2006, 12:10 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Yes you can...but it is always recommended to do it when the engine is warm if you want an exact reading result.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 09-25-2006, 01:01 PM
Scott R's Avatar
It would be better if oyu could swing a leakdown, I had nominal compression, however I had a 35% leak past the rings.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-25-2006, 01:07 PM
What I am concerned about is a damaged valve, the engine was running fine when removed but there was a slight knocking sound.
My guess was that a compression test would easily identify if I had a damaged valve.
1979 Ford RS2000
1980 Mini 1275GT
Old 09-26-2006, 12:53 PM
If you suspect a damaged valve, minimize engine rotations. I would perform a leakdown test at this point. Before testing, remove the valve covers and verify the suspected valve is not so bent it is stuck open (valve vs piston = bad).
If okay, manually rotate engine so test cylinder piston is at TDC, end of compression (careful), then do it. If you bent a valve, it'll be pretty obvious where the air leak is.
Sherwood
Old 09-26-2006, 01:24 PM
Ok
Thanks for the help all.
1979 Ford RS2000
1980 Mini 1275GT
Old 09-26-2006, 01:31 PM
