rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Trouble installing heater cables
I'm replacing the cables to my new heater boxes. I greased them and started feeding them through the heater cable guides from the interior of the car. On both tubes the cables stopped feeding in. Something is obstructing them with about 1- 1/2 feet to go. Can anyone help me with this?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-26-2006, 04:15 PM
You need to crawl under the car to guide them thru the flexible tubes that run from the center tunnel to the flapper boxes.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 09-28-2006, 07:57 AM
pull the flex tube off the tunnel tube and feed the cable out an inch or so, then use needlenose pliers to get it started into the flex tube, then push the flex tube back onto the tunnel tube and continue pushing it through from the front.
206 637 4071
Old 09-28-2006, 08:11 AM
rs6er's Avatar
Thank's for the suggestions. I had given up on anyone answering. I managed to get them further in. They only have about 8 inches to go. Do I just pull the plastic guide tubes out of the metal tubes near the trans.?
John
Old 09-28-2006, 12:57 PM
yes, the last obstacle is where they come out of the flex tube at the heater valve bracket. the black plastic cover needs to come off the very end of the hard tube on the bracket. it has a small hole that the cable usually doesn't hit dead center.
206 637 4071
Old 09-28-2006, 01:17 PM
rs6er's Avatar
My cables didn't make it that far. One of my plugs (PP calls it a grommet) is missing, and the cable hasn't gotten that far. I'll try pulling the plastic guide tubes off. I should be able to feed the cables through then. I didn't realize how they were attached to the metal tunnels upstream. I guess they are just pressed on.
By the way, when I took the levers off all the pieces fell out. There's a small picture in the Bentley, but the parts pictures in Pelican shows them much more clearly.
John
Old 09-28-2006, 01:38 PM
