Guest
Posts: n/a
engine
does anyone know what the weight of a 3.0 is
Guest
Posts: n/a
A 911 engine is 401 pounds
Guest
Posts: n/a
Guest
Posts: n/a
The answer is : depends...
The factory made at least 5 engines with 3 liters displacement. -The SC engine -The Carrera 3.0 engine -The Turbo 3.0 engine -The RS 3.0 engine -The RSR 3.0 engine Now I guess you are talking about the SC engine. The weight is around 400 Lbs. The carrera 3.0 weighs around 330 Lbs. The turbo 3.0 is more than 400 Lbs. My $0.02, GeorgeK |
Guest
Posts: n/a
As long as someone has the stats:
How much does a 1970 2.2 weigh? How much does a 1992 3.6 weigh? ------------------ --------------- Jack Olsen 1973 911 T sunroof coupe http://members.rennlist.com/jackolsen/Jalopy.html |
