Proper compression testing
Hello, I need to perform a compression test on my 73T 2.4 MFI. What is the best way to disable the electric fuel pump as well as the ignition to ensure I don't do any damage to the eletronics. Any other pointers would be appreciated.
Thanks, Joe
Old 09-29-2006, 05:23 AM
Thanks Wayne, so this is the large connector on the CD box and does anybody know where the fuse is for the pump on a 73T?
Old 09-29-2006, 06:43 AM
Zeke's Avatar
Also remove the center fuse on the rear relay elec console. This disables the cold start squirters. Just to be sure, even with the fuel pump off. I belive the fuel pump fuse is in the front and labled inside the fuse cover.
Old 09-29-2006, 07:17 AM
Thanks Milt, appreciate it. Hope to do some good diagnostic work this weekend and get this baby running properly again.
Joe
Old 09-29-2006, 07:21 AM
