DW SD's Avatar
what is minimum thickness for rear 930 turbo rotors (before tossing)?
Guys,
What is the minimum thickness for rear 930 turbo rotors? Fresh should me 28mm thick.
If I have some that are 27.x mm without large grooves, should I machine them (surface ground) smooth or just run them and toss them later?
Thank you,
Doug
1971 RSR - interpretation
Old 10-03-2006, 02:46 PM
Bill Verburg's Avatar
26mm wear
26.6mm after machining
Bill Verburg
Old 10-03-2006, 02:49 PM
DW SD's Avatar
Thanks!
If they meet the specs provided.....Would you machine them if you have small grooves or just run them?
I was planning on having them surface ground flat, not turned.
Thank you,
Doug
Old 10-03-2006, 02:54 PM
If they are already at 27 w/ grooves, I would toss them now
Bill Verburg
Old 10-03-2006, 03:00 PM
Oh Haha's Avatar
Can you machine drilled rotors? A buddy has some serious braking vibrations on his 930. No vibrations at speed. They are stock AFAIK.
Pacific Blue
Wayne
Old 10-03-2006, 06:23 PM
Apologies for resurrecting an old post, but I've been searching for the answer to this same question, but for the front, floating 930 rotors.
Mine are at 29mm in the front. Time to replace?
Old 10-11-2007, 02:32 PM
GrantG's Avatar
Yes, passed time. The fronts start at 32mm and should be tossed at 30mm, afaik...
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 10-11-2007, 02:35 PM
I've had them ground, you want to leave a nice x-hatch pattern for the pads to bite on.
They can be machined but then the surface needs to be prepared by grinding.
Bill Verburg
Old 10-11-2007, 02:36 PM
If it's even close to minimum invest in new, all that lost metal reduces the rotors functionality.
30.6mm is the symmetric machining limit, 30mm the wear limit
Bill Verburg
Old 10-11-2007, 02:40 PM
