Porsche virgin's Avatar
Originally posted by rs6er
It was pretty simple. As I am in Westchester too, I could certainly help you.
That would be hugely appreciated, if you had some extra time over the next few months. I'll PM you and we'll talk offline.
Thanks very much.
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 10-04-2006, 08:49 AM
greglepore's Avatar
Before you do anything, look at signaldynamics.com - 1/8th in led, plenty visible, does everything a traditional voltmeter does, no need to cut anything. Keep the clock.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 10-04-2006, 09:33 AM
charleskieffner's Avatar
volt gauge in console...............YUMMY IDEA. thanks wil for spending more of my hard earned money! great idea and useful. ghia we have has one and has on occasion acted up and alerted us to upcoming problems.
Old 10-04-2006, 09:39 AM
coupla things...
Like I said... I did a comprehensive search and found most of the alternate aproaches being proposed here. Just me...I don't want an important instrument like a voltmeter in an area that is not almost direct line-of-sight. So...I don't want it near my ignition switch nor the easily mounted console area. THAT's where I might relocate my less-important stock clock...if at all.
I also tried your link ( Greg) on the signaldyanamics page, but no amount of searching with proper keywords got me anywhere close to a voltmeter device. I did see various LED devices in my other searches but would prefer ( in order) a gauge that looks stock .....or maybe even a digital numeric call-out since the resolution would be "fine" even though a "pointer" would be better for rate-of-change.
I also found this install guide interesting, since some of you brought this topic up->
http://www.egauges.com/pdf/vdo/0-515-012-068.pdf#search=%22VDO%20voltmeter%20%22
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-04-2006, 09:51 AM
greglepore's Avatar
Sorry, Wil-http://www.signaldynamics.com/products/Modules/HUVM.asp
is the page. Yes its tiny, but the vis is very good and the resolution good as well. It mounts line of sight, in the dash or .... mine is in a clock plug under a boost gauge.
Greg Lepore
85 Targa
Old 10-04-2006, 11:18 AM
Here is the thread I was refering to:
Adding gauges to the center console
And another cool idea:
Photoshop, Tach advice/help needed
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 10-04-2006, 12:41 PM
randywebb's Avatar
I like rs6er's install. Also the analog needle can give a little bit of time series data. I find the LEDs hard to watch and they don't match the other gauges.
Will - I bet VDO can tell you about the lighting on the gauge.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-04-2006, 01:03 PM
