cali74's Avatar
Project Update: getting closer
I'm creeping ever closer to the non-existant finish line, and I know everyone loves pictures....so I thought I'd post an update.
Actually, since Doug's coming over tomorrow (and we all know the silver RSR standards he's got), I felt like girls often do and had to clean up the garage...which led to some picture taking :-)
First up, a gratuitous rear end shot. Kinda dark but you get the idea...
74 911 with '95 3.6l
Old 10-03-2006, 06:41 PM
cali74's Avatar
Then how about one of the engine, pulled out of it's normal resting place (the side of the garage) for inspection...
Old 10-03-2006, 06:42 PM
cali74's Avatar
Hmmm, onto the front suspension where I've assembled some bits, but haven't gotten it all torqued into place...
Old 10-03-2006, 06:44 PM
cali74's Avatar
Rear suspension is assembled as well, here's one side of the Wevo SPS in place...
Old 10-03-2006, 06:45 PM
cali74's Avatar
Next up is the smuggler's box where I fabricated some mounts for the different fuel pump. This one was weird cause it had an odd size outlet, so I got an AN-6 adapter that goes into a check valve which then goes to the back of the car. On the inlet side is a pre-filter just in case any junk comes from the tank.
Old 10-03-2006, 06:48 PM
cali74's Avatar
A little cover for the nasty hole left from some previous A/C unit...rivet nuts are great here, so I can unbolt this guy and get access to the fuel stuff from below...
Old 10-03-2006, 06:49 PM
cali74's Avatar
Gratuitous front end shot :-)
Old 10-03-2006, 06:50 PM
cali74's Avatar
here's the new fuel filter mounted on the inlet side of the 3.6 so I don't ahve to snake around the engine bay. On the outlet side is a Jiffy-tite quick-disconnect so i don't spill fuel when dropping the motor...
Old 10-03-2006, 06:52 PM
cali74's Avatar
on the return side of the engine is a quick disconnect I hooked up through the reinforcement I welded previously. This should give a little more room for the electrical bundle, and it also has a quick-disconnect to pop out the motor...
That's it for now I guess...this project will never end. Can anyone say wide-body....doh! can't start thinking that way :-)
Old 10-03-2006, 06:54 PM
beamonk's Avatar
Send a message via AIM to beamonk
How about some pics of the oil cooler mounts?
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 10-03-2006, 07:22 PM
cali74's Avatar
check out this thread, it has some more pics of the cooler mounts...
Project Update: Finished Por Paint and some bolt ons
Old 10-03-2006, 07:24 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Love the color! as well as the complimentary color on the front control arm, nice touch
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 10-03-2006, 07:28 PM
Jeff Alton's Avatar
Extreme attention to detail, very very nice work.
Cheers
www.turn3autosport.com
Old 10-03-2006, 09:44 PM
Matt,
It's looking great!
You've done a fantastic job on the details. Thanks for sharing your knowledge and expertise. My fuel tank came out better than anything I could've expected from rhino-liner. Thanks again for the tip.
Old 10-05-2006, 02:15 PM
cali74's Avatar
thanks for all the nice comments :-)
Fernando - no problem on the line-x stuff. I was pretty excited myself by the results!
as far as sharing knowledge and expertise - I'm not an expert on ANY of this, and not very knowledgeable to boot, but I can at least share what I've learned from others, and through doing some projects :-) I will say the fun part of this hobby/disease is learning with each step. I think to do another car from the ground up would require an even more extreme approach, thus extending the learning... now THAT would be a crazy car :-)
Old 10-05-2006, 02:20 PM
You are too modest...
I can only imagine how many man-hours you have on this project. It's a testament to your drive and ambition to do things well. Cheers.
Old 10-05-2006, 02:36 PM
Dan in Pasadena's Avatar
Looking very, very good.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 10-05-2006, 02:40 PM
ninelevenick's Avatar
Wow. Nice workmanship. Someday when I'm retired, I'll rebuild me a Porsche too.
Old 10-05-2006, 02:42 PM
jevvy's Avatar
As all have said very nice work.
What are you doing for heat & muffler for your 3.6?
'89 3.2/3.6 coupe
Old 10-05-2006, 02:46 PM
cali74's Avatar
for heat I'm using the stock 993 heat exchangers, and I have the stock muffler with some tips welded on. I'll have to see how the muffler is when it's all together, maybe something new will be needed.
Oh yeah, since I removed the fresh air blower I was going to run new scat type tubing up front straight to the window defroster vents like DW SD did on his RSR. If that blows (i mean, if it sucks, hehe), then I thought about putting an inline fan in the front bay to help move the air.
Old 10-05-2006, 02:50 PM
