Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Wink Dash Center Vent blowing without A/C
I completed this last weekend and I must say that it has been much more pleasant driving my P-car when the top and windows are up.
This was my original plan:
Unfortunately the unit was just too big. I had all the connections sized properly so that I could (in my dreams) use the original ventillation hoses without cutting any. Well it just wouldn't fit due to the angles of the connections between the fresh air blower and the passengers side flapper box and their spacing.
So I had to go with my back-up plan.
Here's the background. I purchased a passenger seat from a guy up in Sonoma about four months ago. Great guy. When I got there he started looking at my car and telling me about it. Due to the conversion, I have a ton of different year parts and so forth. He taught me several things. He also gave me several extra parts for the car that he thought I needed, which was very much appreciated. He figured my center dash vents didn't work because the A/C was removed (correct) and he figure the guide to the vents was also removed. Well this is the one he gave me.
I tried to install that one, but it wouldn't fit with the adapter at the input to it (due to proximitiy to the blower motor's housing). So I cut the adapter off of the vent pipe and used it to connect the hoses to. I was hoping not to cut any, but since the adapter isn't physically secured to anything the pressure of the compressed hoses were too much. So I cut the hoses to fit onto the adapter.
Results were as expected. My dash center vent now blows fresh air, though it shares its supplied air with the passenger side. So the passenger side has a less air supplied to it than it had in the past. Oh well, I usually don't have passengers, and when I do the top is normally down.
I hope this helps someone who is also A/C less and doesn't want to add weight by installing another fresh air motor.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-04-2006, 10:16 PM
kuehl's Avatar
Simply great.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 10-07-2006, 10:36 AM
Hi, Matt,
You said, "I hope this helps someone who is also A/C less and doesn't want to add weight by installing another fresh air motor."
It means that you have a fresh air blower in the smuggler box, or anywhere else?
let me know
Thank you
Old 05-02-2013, 07:37 PM
kuehl's Avatar
Mathieu,
What Matt is saying ......when he deleted his evaporator, and its blower motor, he directed the air from the fresh air motor through the primary AC vent above the radio.
Old 05-07-2013, 05:43 AM
Bumping an old thread yet again.
My euro 3.2 has had its a/c removed, and I'd love to get the center vent working as described. Any advice about what parts to buy?
It works great when the hood is unlatched :-)
1988 M3
84 RoW Carrera 3.2
cars.g93.net
Old 06-26-2013, 01:42 PM
kuehl's Avatar
Looks like the first pic in the thread is HomeDeposit or Louse parts,
Copy the pic, send it to your cell, and walk down the plumbing isle
Old 06-26-2013, 02:36 PM
notmytarga's Avatar
He didn't use the black plastic parts in the first picture (his original plan). The key item is the light colored three-way T-ish looking thing that is not a hardware store item. Was that a gift from the guy at Sonoma?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 06-26-2013, 03:01 PM
Kraftwerk's Avatar
Bumping this once more, since it appears to be so easy, deceptively easy? That light colored 'three-way' seems to be a part that was already on his car, he just re-jiggered it changed its dimension and location.... et Voila! Do I have this right?
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 08-21-2013, 11:16 AM
kuehl's Avatar
Selkirk,
Sounds like you have issues there.
Try posting your question in this section:
Off Topic Discussions - Pelican Parts Technical BBS
Old 09-12-2013, 05:01 AM
Old 09-17-2013, 09:17 PM
