Somatic Negative Optimist
Gunter's Avatar
Question Help find the 14 pin connector in catalog
Hello: I tried searching for the 14 pin connector in the catalog but was directed back and forth. Where is this thing? Anyone?
I tried but what am I missing? This is what I get without success:
Customers who searched for 14pin connector also searched for:electrical plug, Socket Plug, J-123-101-30, harness, electric connector, control plug, Connectors, 14pin, 14 Pin Plug
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-07-2004, 01:06 PM
derek murray's Avatar
Is this what you are looking for? If so, Pelican sells it for $38.07
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 12-07-2004, 01:51 PM
Gunter's Avatar
Thanks Derek, How did you find it? I tried for an hour searching, searching.........Why does it not come up under:"14 pin connector"?
What is the Pelican Parts number for it? Thanks.
Old 12-08-2004, 08:43 AM
I plugged the Porsche part number, shown on the package, into the Pelican Search and came up with their part # OEM-91161211305. It's a special order @ $38.07
It'll show up at the bottom of the page (??)
Warren & Ron, may you rest in Peace.
Old 12-08-2004, 08:52 AM
Gunter's Avatar
Thanks Rick. The point of a search is that one doen't have the OEM part number but uses key words. Not one of the above listed search-words brings you to the part. Grrrrrr. Appreciate your help guys!
Old 12-08-2004, 10:31 AM
randywebb's Avatar
common problem - happens to me all the time
double grrrr.....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-08-2004, 12:47 PM
RallyJon's Avatar
The problem with the search is that is treats each word as a search term. Search on brake wrench and you get a bunch of listings with just "brake" and a bunch with just "wrench".
brake AND wrench doesn't work.
+brake +wrench doesn't work.
"brake wrench" doesn't work.
None of the usual methods of limiting a search work in the Pelican catalog.
993 · 911 · STI · S4 · rally car
Old 12-08-2004, 12:54 PM
I was looking for the same thing a few years ago without success, until fellow Pelican, Jim Sims, provided the number... this board rocks!
'70 911S 1002938
Old 12-08-2004, 12:59 PM
randywebb's Avatar
I found these in the PET -- they are under 944, BTW.
Wayne needs to license the Google search engine.
Old 12-09-2004, 02:01 PM
Gunter's Avatar
What is PET, please?
Old 12-10-2004, 09:57 AM
randywebb's Avatar
PET is the CD based parts catalog that Porsche made. There are bootleg copies out there, and apparently a better version now, that they wised up on and started selling.
You need one.
Old 12-10-2004, 11:13 AM
911SCfanatic's Avatar
This appears to be for the two male 14 pin connectors on the engine relay panel.
Anyone know the p/n for the female connectors (one for the engine wire harness, and one for the harness from the tunnel)? Thanks.
Bill G.
'68 911 Ossi Blue coupe
Old 10-05-2006, 07:29 AM
Jeff Alton's Avatar
PET is also available on line for free at porsche.com
Cheers
www.turn3autosport.com
Old 10-05-2006, 07:57 AM
Cheers
Thanks, but I already spent 20 minutes without luck. If you can find it, you're a better man than I.
Bill G.
Old 10-05-2006, 08:01 AM
Jeff Alton's Avatar
Try this link, it takes a while to load....
http://www.porsche.com/canada/accessoriesandservices/classic/classic-originalparts/originalparts-originalparts/
Cheers
Old 10-05-2006, 09:02 AM
Cheers
That's the same thing I already looked at for 20 minutes. It doesn't list connectors separately from the wiring harness.
Bill G.
Old 10-05-2006, 09:38 AM
Jeff Alton's Avatar
Ooops, I thought you could not find PET, I misread what you were saying!
Sorry
Old 10-05-2006, 10:21 AM
PET for a 911SC shows two different "plug socket 14 pole" entries. One is the one pictured above (911 612 113 05) and another one (911 612 115 05. The text is the same for both. Is the "115" version the female socket?
Old 10-05-2006, 04:45 PM
