Somatic Negative Optimist
Hello: I tried searching for the 14 pin connector in the catalog but was directed back and forth. Where is this thing? Anyone?
I tried but what am I missing? This is what I get without success: Customers who searched for 14pin connector also searched for:electrical plug, Socket Plug, J-123-101-30, harness, electric connector, control plug, Connectors, 14pin, 14 Pin Plug
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Is this what you are looking for? If so, Pelican sells it for $38.07
'70 911S 1002938 '70 Ducati Mark 3D 350 |
Thanks Derek, How did you find it? I tried for an hour searching, searching.........Why does it not come up under:"14 pin connector"?
What is the Pelican Parts number for it? Thanks.
I plugged the Porsche part number, shown on the package, into the Pelican Search and came up with their part # OEM-91161211305. It's a special order @ $38.07
It'll show up at the bottom of the page (??)
Warren & Ron, may you rest in Peace. |
Thanks Rick. The point of a search is that one doen't have the OEM part number but uses key words. Not one of the above listed search-words brings you to the part. Grrrrrr. Appreciate your help guys!
common problem - happens to me all the time
double grrrr.....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
The problem with the search is that is treats each word as a search term. Search on brake wrench and you get a bunch of listings with just "brake" and a bunch with just "wrench".
brake AND wrench doesn't work. +brake +wrench doesn't work. "brake wrench" doesn't work. None of the usual methods of limiting a search work in the Pelican catalog. |
I found these in the PET -- they are under 944, BTW.
Wayne needs to license the Google search engine.
What is PET, please?
PET is the CD based parts catalog that Porsche made. There are bootleg copies out there, and apparently a better version now, that they wised up on and started selling.
You need one.
This appears to be for the two male 14 pin connectors on the engine relay panel.
Anyone know the p/n for the female connectors (one for the engine wire harness, and one for the harness from the tunnel)? Thanks.
Bill G. '68 911 Ossi Blue coupe |
PET is also available on line for free at porsche.com
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Try this link, it takes a while to load....
http://www.porsche.com/canada/accessoriesandservices/classic/classic-originalparts/originalparts-originalparts/ Cheers
That's the same thing I already looked at for 20 minutes. It doesn't list connectors separately from the wiring harness.
Ooops, I thought you could not find PET, I misread what you were saying!
![]() Sorry
PET for a 911SC shows two different "plug socket 14 pole" entries. One is the one pictured above (911 612 113 05) and another one (911 612 115 05. The text is the same for both. Is the "115" version the female socket? |
