Somatic Negative Optimist
Gunter's Avatar
Cool Almost there with more HP
3.2 SS, 98mm Mahle cylinders, JE 9.8CR pistons, 964 cams, '78 CIS on an '82 bottom.
The plan:
Take out my current 3.0 liter, swap tin ware, SSI's with heater back-date to the 3.2 SS, take the 915 transmission to JW for some work.
Then mount the 915 to the 3.2 and install.
(And hope it'll run as intended)
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-06-2006, 09:03 AM
Gunter's Avatar
Picture of the above:
Old 10-06-2006, 09:17 AM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
That looks good enough to eat - do you have more pics Gunter??
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 10-06-2006, 09:25 AM
Bye, Bye.
Scooter's Avatar
Can't wait to see it in person. Good luck with the installation.
Elvis has left the building.
i'm just a cook
onlycafe's Avatar
over the summer my '79 targa went to 3.3 , s cams , a bit of porting and polishing , turbo oil pump , backdated exhaust , and a set of 46mm webers. fuel economy down the drain, but what a ride.
get ready to have a ton of fun. best of luck with it.
david
Old 10-06-2006, 09:30 AM
Gunter's Avatar
I'll take more pix during the actual swap.
Plan to do one more run with my stock 3.0 before winter comes.
Winter
Old 10-06-2006, 09:42 AM
coolcavaracing.com
Kroggers's Avatar
Originally posted by Gunter
Winter
Hmmmm, yes winter. I am already prepping my baby for the winter storage. Nothing here but rain and cold wind
Old 10-06-2006, 09:48 AM
bivenator's Avatar
winter?
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates
88 coupe
Old 10-06-2006, 10:17 AM
goldgunner's Avatar
Very similar to what I've done: 3.0 to 3.2 max moritz 10.5:1 with the 964 cams - but I went with the Carrara intake manifolds, fuel rails, etc and Electromotive EFI.
Tuning continues: still trying to figure out how to get more gas into it.
Appears the SC fuel pump might be putting out enough; might / probably have to change the fuel pressure regulator to the 964 version; might have to go to larger injectors than the Carrera's.
Be alert - you very well may also be lean at the top end and need more gas.
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 10-06-2006, 10:25 AM
al lkosmal's Avatar
3.2 SS
looks nice Gunter. When will there be fire?
RGruppe #669
http://www.x-faktory.com/
Old 10-06-2006, 11:27 AM
Deschodt's Avatar
The belt looks like it's mounted backwards ;-)
probably a type I've never seen ;-)
Old 10-06-2006, 11:30 AM
Gunter's Avatar
That's the beauty about CIS, you can really adjust the mixture.
I have seen 3.0 conversions to 3.4 with 100mm MM P/C's, enlarged TB, 20/21 cams with stock pump and CIS. (Dane's engine) It run like a bat out of hell.
My set-up is essentially an early '78-'79 SC with slightly larger P/C's and a little more lift on the 964 cams.
I like to keep things simple; no more Lambda but the rest stays: WUR, AAR, AAV, CSV and Decel.Valve.
10.5 CR is the absolute maximum for a single plug; I didn't want to go that high.
Al: Start-up is either very late this year or in the spring. No hurry, my stock 3.0 runs pretty good.
The belt is designed to last longer with the outside notched out.
Old 10-07-2006, 08:11 AM
There is no beauty to CIS, EFI on the other hand, now that is beauty.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 10-07-2006, 08:38 AM
