wxman's Avatar
Front rotor replacement
I was attempting to replace my front rotors this morning on my 87 Targa. From Waynes book it sounded like a straight forward project; remove the calipers, remove two screws on the rotors and pull the old rotors off. It appears I must dismantle the end part of the axel to slide the old rotor off. I am not sure how to accomplish this. Am I missing something?
Thanks,
Doug
Fresno
87 Targa Daily Driver
Old 10-06-2006, 10:15 AM
aj88cab's Avatar
Front rotor replacement on these cars is a bit more invloved than most any other car. Your description above sounds like the rear rotors BTW.
You have to remove the brake calipers, then the grease cap, loosen the hex head bolt that secures the hub bolt, remove the hub bolt, pull the entire hub off and be careful with the bearings, they will fall out. Then you need to unbolt the rotors from the hub and install the new rotors. Installation, as they say, is the reverse.
You should clean and repack the bearings and you will need to install new seals on the backside of the hub.
Thats the short version, a search will probabbly get you more details, including several methods for removing the grease cap!
Good luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 10-06-2006, 10:27 AM
What is the torque on the fasteners that attach the rotor to the hub?
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 02-15-2007, 07:19 PM
aj88cab's Avatar
Per the Bentley manual - 23 Nm (17 ft-lb).
Old 02-16-2007, 03:55 AM
Thanks for the response.
One more, what is torque for the fastener on the bearing retaining nut.
THANKS!
Bill
Old 02-16-2007, 07:17 AM
Early_S_Man's Avatar
Porsche Crest
That M7 Allen bolt gets 10 lb-ft or 15 N-m.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-16-2007, 07:24 AM
