Door Skin or New Door?
How difficult is it to replace the door skin with one from Stoddards or Rest. Design? Or should I just get a whole new door and install it. I would like to just replace the skin so I can keep the alignment of the door and gaps.
Thanks,
Jason
1972 911T MFI
1995 911 C2
Old 10-06-2006, 05:07 PM
I spend a lot of time in body shops and to the best of my knowledge you will have to remove the doors to put new skins on the door. You need a few special tools and experience to do a good job.
Thanks,
Chris Jacob
85' Carrera
Old 10-06-2006, 07:57 PM
Warren Hall Student
Bobboloo's Avatar
You can pull the pins and that way you don't loose your alignment but I think you'll still have to re-adjust to get the fit right. Replacing the skin and expecting it to line up isn't any more likely than just swapping doors and hoping it will line up.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-06-2006, 08:43 PM
47silver's Avatar
door
would 77 or above doors fit? if so i would get a set of them as they are galvanized and resist rust. I did not replace mine had them repaired and the one needed repaired after only 2 year. On the other hand i replaced the front fenders with galvanized and they are perfect.
if you can pick up a used pair of newer ones,
1975 911S Targa
Silver Anniversary Edition
Old 10-06-2006, 09:29 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
they should fit just fine
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 10-06-2006, 11:21 PM
BReyes's Avatar
How bad is it ? Sure you can't fix properly? Pics?
Regards,
Bernard
Old 10-07-2006, 01:49 AM
I was just hoping to remove the pins and then re-skin the door and that would help me keep the alignment. Here is a pic. There is some bodo repair done in the front too, I will take a pic of that later. Where did you buy the galvanized fender and door at? I have not seen them anywhere. I would like a new fender too. There was a poor repair done by PO on my fender.
I will send more pics and the repairs go on. I am also repairing the door post, same side. After reading some other posts I think I should do that first to keep the alignment. What do you guys think? Any tips or sugestions before I start? I am using a Stoddards or Rest Design piece for that.
1972 911T MFI
1995 911 C2
Old 10-07-2006, 09:09 AM
Oh I see what you mean on the galvanized doors. Just get 77 or later so they come galvanized from the factory, right. Would the fenders fit on a 72?
1972 911T MFI
1995 911 C2
Old 10-07-2006, 09:14 AM
Warren Hall Student
Bobboloo's Avatar
It's usually cheaper to just replace the whole door. You can find used ones cheaper than the price of the skin and you save the labor cost of installing the skin. Besides your door shell looks bent and might have rust issues as well.
The rust in your rockers is bad news. It can be fixed but usually requires the replacement of the inner and outer rocker panels on both sides of the car. The replacement panels are cheap but the labor isn't.
Bobby
Old 10-07-2006, 10:00 AM
I have also reskinned my doors and it was a lot of work when you consider the lead and/or filler that is used at several places where the top of the skin meets the door frame. If all else is good, I'd consider just replacing the bad metal, and not the entire skin. That said, I'd agree now that the easiest solution is a later galvanized door.
'56, '59 356A Coupes
'67, '68 912 Coupes all gone
'72 911T coupe
Old 10-07-2006, 04:37 PM
47silver's Avatar
fenders
i bought them from the pelican classifieds. jim 74911s
he was changing his 77 fenders for racing i guess and i saw his post and bought them for? 500? including shipping.. that was 2.5 years ago. they were shipped and packaged nicely and onlyhad to mod a little on the gas area.....
i should have bought doors....and will probably scoop up a pair to have.
it takes some time and skill to align, the guy who did my body work/paint did it so i cannot help you there.
1975 911S Targa
Old 10-07-2006, 07:57 PM
techweenie's Avatar
I have a galvanized door shell in nice shape. It's from an SC so has the big SC mirror holes, though.
$225 for the driver's door shell, picked up in Los Angeles.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 10-07-2006, 10:54 PM
