Guest
Posts: n/a
930 Spark Plug Question.... HELP! Twin Plug?
I currently own an 85 930 with a twin-plug conversion. I'm trying to find out what type of spark plug is recommended for this setup and what type of gap? I recently had it serviced and I don't think they installed the proper plugs. I also suspect they set the gap incorrectly.
Any suggestions would be greatly appreciated. |
Guest
Posts: n/a
I don't know why the twin-plug heads would change the recommended sparkplug, so I presume the 'normally' recommended Bosch W3DPO would be the same one expected. Is your boost higher than normal?
What plugs were installed, and what gap did they set them at? ------------------ Warren Hall 1973 911S Targa |
Thread Tools | |
Rate This Thread | |
