durn for'ner
Does your Carrera use a performance chip ?
Curious to know how many of you Carrera owners have switched to some kind of performance chip. Not least since I am almost convinced I will do it myself in the near future. Steve Wongs products seem particularly popular, hence a separate option.
Markus Resident Fluffer Carrera '85 |
durn for'ner
Bumping this one myself - if there are any more.
One vote for option no 1. Wonder who that might be..
Steve Wong Chip in my '89 Cabrio. Love it!!!! Runs smoother, down shifts better, revs free'r, etc.
Highly recommend. Don't have to think twice on this one.
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
durn for'ner
So far almost 10% are afraid a performance chip will harm the engine. Thats not statistically significant, but still a bit surprising.
Loren - you have a twin ??
Senior Member
Another vote for Steve Wong. Used his chip for years until going the 3.6 transplant route.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
MBruns for President
I see Loren voted 3 times
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Chipped!
Autothority chip that's been remapped for the new cams, head work, K&N filter and Billy Boat single outlet exhaust.
She really hauls the mail. Steve Ed
My life is great! Prev. rides - 87 924GT, 86 Carrera, 69 Targa, 85.5 944 track car, 86 951 84 Triple Black 911 - Current |
Needs another choice: "Modify the DME ECM to the late ('89) 28 pin chip."
This modification is usually half the cost of a performance chip and yields better overall results without the problematic issues, e.g. 1. finding 98+ octane 2. emission test failures; Flunked CA smog test 3. damaged engine; http://forums.rennlist.com/rennforums/showthread.php?t=269781&highlight=broken+rings Check here to see what performance chips really do; http://www.systemsc.com/tests.htm
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 10-04-2006 at 07:59 AM.. |
Light,Nimble,Uncivilized
Prior owner installed a Club Sport chip which apparently only raises the redline to 6800rpm.
Drago '69 Coupe R #464 |
3.4 Bigger is better
Problamatic issues? Like to know what those are? My car has only run better with each change.
I have had three chips in my car. First was an Autothority that had been in the car for more than 60,000 miles and two SteveW chips. One was in for two years before the rebuild. Did a rebuild due to head studs breaking and there was no damage to the rings or pistons. If the chip had done damage to the engine I would have seen the signs of it. Proof, I think that about says it all and I am at red line every chance I can go there
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Installed by previous owner. Redline is 6800 rpm. So far so good.
Uh oh, looks like Markus has got some money burning a hole in his pocket...
![]() ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
durn for'ner
Ian,
I was kind of hoping you would miss this post, since you know how long I have been pondering this issue. Almost embarrassing. What got me thinking is the fact that my Euro car was imported from Germany with a cat. The first owner in Sweden had it removed along with a O2 sensor I presume. I was under the impression that would need a remapping of the DME as the O2 reference is gone ??? I have no possibility finding out if that was done (if its needed). My car runs great in any case. With a new SW chip that potential problem would be gone, right ?
What you need to do Markus is get stuck in there and spend a whole bunch of money changing stuff to the point that you forget how good she was.
Then in a fit of confusion as you slide down the slippery slope, call Steve Wong to sort it all out for you. See you on the slide ;-) Phil
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
durn for'ner
I just took the DME box apart to localize the number on the chip for Steve W. I have now mailed my order !
I did not realize how small that chip is and how tiny those little metal claws are. How I am going to switch chips without braking those little feet is a mystery to me !!
Steve W. chip has been one of my best investments. My Targa has a different chip per PO and doesn't perform like my coupe with a SW chip.
Jim '88 Targa |
Friend of Warren
As for me I have a rebuilt 3.2 with SSI's and a Steve W. chip.
Kurt V No more Porsches, but a revolving number of motorcycles. |
My dad's targa has a SW chip and it goes like stink, no problems with the motor either as it was just torn apart due to...other reasons...
You made a wise choice Markus!
Matthew “Sometimes the questions are complicated and the answers are simple.” |
durn for'ner
Thanks Kurt,
As I understand, the stock euro exhaust set up doesn´t strangle the 3.2 too much. Besides, SSI costs the thick end of big bundle of money, right ? And honestly, I am not capable of handling more than 231 odd ponies anyway. ![]() Sounds good, Matt !
Friend of Warren
