PhatA55's Avatar
Need help fast
I'm in downtown Cincinnati, OH with bad driver side rear wheel bearings. I need a good repair shop and I don't know anyone here. Can someone recommend a reputable shop? Also, does anyone know what a fair estimate would be?
--Mark--
1979 RoW 930
1999 BMW Z3
Originally posted by randywebb
It is the people who have some kind of psychological problem and use the car (or some hierarchy they set up involving the cars) to try to elevate their personal sense of self-worth that irks me. I feel sorry for them of course, but they are difficult to put up with.
Old 10-02-2006, 10:07 AM
Although for a (Porsche) track car I found this on the PCA site...every other recommendation I've seen is near Cleveland....
"For a track car in Cincinnati, that is easy. Call John Wright, Wright Tuning. http://www.wrighttuning.com/ "
4009 Borman Drive
Batavia, Ohio 55103
513 735-2300
Hopefully a local will chime in soon.
Warren & Ron, may you rest in Peace.
Old 10-02-2006, 10:21 AM
PhatA55's Avatar
I've got it under control now. I had an idea. Uhaul truck+trailer, one way home = $191. Heck, I can't get it towed for anywhere near that. Now I can fix it myself instead of the $900 I was quoted earlier. Thanks for looking and offering advise.
Mark
--Mark--
1979 RoW 930
1999 BMW Z3
Old 10-02-2006, 12:54 PM
Sure it's rear wheel bearings? Did you check for loose CV joint bolts?
Old 10-02-2006, 05:12 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Sheesh, I'm sorry. I feel like a horses a$$ for not checkiing in earlier in the day, I'm maybe 10 minutes out of downtown. If youre still around, I've PM'd you with my number, give me a call if you need help.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 10-02-2006, 06:37 PM
PhatA55's Avatar
No I didn't, I was driving into town and the sound made me think bearings but anything is possible. It's in a parking garage right now, not leaving until Friday. I plan on looking at it closer after work today.
--Mark--
1979 RoW 930
1999 BMW Z3
Old 10-03-2006, 04:16 AM
PhatA55's Avatar
Thanks for the offer, I'll let you know if I need help.
Mark
--Mark--
1979 RoW 930
1999 BMW Z3
Old 10-03-2006, 04:19 AM
PhatA55's Avatar
I did some searching and now I'm not sure if it's bearings or cv joints. The noise started as squealing which then became a combination of that and grinding with some clunks mixed in. It sounded like a bearing that had locked up, overheated, and had the balls come out of the race in an electric motor. It would do that for a minute then stop and become a very low drone. Then it would start over a few minutes later. If I drive slow it's not bad but at highway speeds it is. What do you guys think? Another curious thing is this morning when I tried to start the car it would crank but not fire, this also happened yesterday. The generator light didn't come on while cranking like it usually does this morning, though. I didn't have time to look deeper since I needed to get to work.
--Mark--
1979 RoW 930
1999 BMW Z3
Old 10-03-2006, 04:48 AM
PhatA55's Avatar
Got it home, Uhaul ended up costing me $150. I started tearing it down and it is definately bearings. I pulled the drive shaft and looked into the trailing arm from behind and saw missing pieces in the bearing cage. Now my problem is pulling the hub. I have tried a slide hammer with no luck. My manual says to use Porsche tool P297 which looks like a solid shaft of steel to drive the hub out from the back side. I made one and tried driving it with a 5lb hammer but it still won't budge. Looks like I'll have to pull the trailing arm.
--Mark--
1979 RoW 930
1999 BMW Z3
Old 10-08-2006, 09:20 AM
see the picture on down the thread a bit. be careful if it's on jackstands, that you don't pull the car off them onto yourself. keep the other wheel on the ground.
How do I get my rear wheel hubs off
206 637 4071
Old 10-08-2006, 09:29 AM
PhatA55's Avatar
Thanks John. I was scared to use my 36" prybars for fear of bending the hub but it took very little effort once I tried it. It popped right off. Here is a pic of the mayhem.
--Mark--
1979 RoW 930
1999 BMW Z3
Old 10-08-2006, 10:52 AM
