jacko241's Avatar
930 trailing arms
What is the easiest way to identify 930 trailing arms?
Joe
996 GT3 RSR
Old 10-07-2006, 10:09 AM
By their size and hub widths,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-07-2006, 10:50 AM
jacko241's Avatar
Any measurements?
Joe
996 GT3 RSR
Old 10-07-2006, 10:56 AM
Ever jump a Porsche?....
78targa's Avatar
Steve's right. The 930 trailing arms look like they are on steroids. Much beefier and the arm tubing almost has a square look to it.
I guess as far as measurements, you could look at the holes for the rear caliper spacing. Figure 74-89 trailing arms have a 3" spacing while the turbo arms have 3.5". The turbo arms also allow the hub to sit out AFAIK remember 1" more than the standard ones. Of course that might be a bit harder to measure since you would need a right angle.
Hope this helps a bit.
Casey
Road-rally, Targa Newfoundland junkie!!!
1969 RSR 3.4L PCA class GT-3 (in progress)...1800 lbs and dropping
Thinking of driving in TARGA NEWFOUNDLAND? Contact me and I can help answer your questions. The event is awesome!
Old 10-07-2006, 02:02 PM
Joe:
They are easy to spot simply by observing the cast lugs for the brake caliper mounts that lies BEHIND the axle centerline, instead of in front, like the 911 ones.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-07-2006, 02:09 PM
jacko241's Avatar
Ahh, thanks guys. Steve, I had forgotten that!
Joe
996 GT3 RSR
Old 10-07-2006, 03:53 PM
