Porsche-pa
75Carrera's Avatar
E-Light flashes wherever key is on???
I have a 75 911 Carrera. Just recently the e-light (top/center of the speedo) flashes and makes the same clicking sound as if the ER lights were engaged anytime the key is on. The emergency lights do work propery when engaged. When the turn signal lever is engaged both directional green arrows flash at the same time but the signals are working properly. I pulled all my corner lights and cleaned the sockets and bulbs. No change.
I can't find the flasher repay (where the heck is it?) and I checked to see if my e-brake was disengaging the brake warning light (again I can't figure out where the switch for that is either)
Help...
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 11-15-2006, 02:19 PM
Porsche-pa
75Carrera's Avatar
I'm thinking this may be a relay issue. I've checked everything else and researched here on the tech and on past theads. Still looking for some input... bump
Also rans...
Donny
Old 11-15-2006, 03:20 PM
I deleted my previous answer because it didn't address your issue. I was daydreaming. Sorry.
Sherwood
Old 11-15-2006, 08:07 PM
The Chef
Guest
Posts: n/a
2 things will trigger the light and relay to go off. A bad ebrake switch or the 2 wires the are attached to the master cylinder. Unplug the 2 brown wires on the master and see if it still flashes.
Old 11-15-2006, 10:23 PM
