Senior Member
targa88's Avatar
Steering column
Model:1988 Carrera.
Concern: while driving at slow speed there is a sound coming from the lower part of the steering column (near where it joins the transaxle) - as if something is rubbing.
Does not appear to occur at high speed (mayb just not as noticeable).
There appears to be some play in the steering.
Also occurs sometimes when locking hard to the right (as I back up).
The car has turbo tie-rods and has been lowered.
Diagnosis or cure?
Targa 88
www.pelicanparts.com/gallery/targa88
There is speed.... and then there is VELOCITY
Old 10-07-2006, 06:20 PM
Zeke's Avatar
Well, the transaxle is under the rear window and the steering doesn't go there. When you say "play" in the steering, is this up and down, or you can turn the wheel while parked some w/o moving the front tires?
When you lowered the car, was there any work done to the steering rack, as in spacers? Answer a few more questions and make a few more observations and the problem will come to light.
Old 10-07-2006, 08:04 PM
Senior Member
targa88's Avatar
Milt,
More info:
I did not lower the car(done by previous owner) - but from I can see there are no spacers.
I can feel the play and vibration in at my feet. So, I am assuming this is where the steering column joins the front axle.
When the car is stationnary there appears to be some play from left to right.
IT does not sound like metal grinding.
Hope this helps
Targa 88
Old 10-07-2006, 08:09 PM
Targa88 -- Did you resolve your 'rubbing' problem? I also have an 88 Targa with perhaps a similar problem (that's how I found your post). Initially the rubbing sound (like a moan, more than anything) came when I turned slightly to the right, but then disappeared as I continued to turn. Now the sound comes comes when steering straight (above 30mph), and disappears when turning left or right. The sound does not transmit any vibration up the column -- and has not gotten any louder. Any of this similar to your noise?
Gordo
Gordo
'88 Targa
Old 11-14-2006, 12:08 AM
randywebb's Avatar
might be time to put the car on jack stands & push pull on each F wheel at 3 & 9 O'clock
then at 6 & 12 o'clock
- feel for any play & report how much and where
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-14-2006, 01:09 PM
Thanks for the response, Randy. I did jack the car up, rotated each tire to see if was doing anything unusual. Also gave it the push-pull test, as you suggested -- all seems tight. Then went out for a spin, the 'moan' was still there -- until I tapped the brake -- no moan. So, the moan goes away when turning (l or r), and when braking, even ever so slightly. Also, the moan is more pronounced when going down a hill, less so when going up.
I will now search other threads, re: brake noise, to see what I find.
Gordo
'88 Targa
Old 11-14-2006, 05:18 PM
Old Member
Gordo
Check your brake pads. I've seen the the caliper piston hang when the pad is worn-out causing a dragging brake (sometimes heard as a moan).
Clifton Brown
https://www.mancalamarketing.com
Old 11-15-2006, 09:30 AM
Thanks for the tip, Cliff. We will pull the wheels to see what we can see.
Gordo
'88 Targa
Old 11-15-2006, 11:33 AM
Walt Fricke's Avatar
Porsche Crest
Gordon
Some more things to think about for steering play:
Among the things to suspect for steering play is the "hockey puck" system which connects the shaft coming up out of the rack and pinion to the shaft(s) coming down from the steering wheel. This is a vibration isolator, but the steel tubes and other bits and pieces, maybe even the rubber part, can wear just enough that there is a little stick/slip movement. Feels tight, but when forced will move a little. Replacing it all just to be sure (bolts, bend tab washer-like bits, steel tubes, the rubber puck part) is the cure, as tightening won't do anything.
While in there looking at things (you have to remove a cover in the trunk), check to see if raising the steering rack with spacers (the normal bump steer kit) has pushed things up enough that they touch other things. Or put the rubber bushed steering column intermediate bearing into too much of a bind.
You can also pull the gravel shield underneath this part of the car (with the car up on jack stands) to see if the two bolts that hold the steering rack are tight. If they aren't, the rack assembly itself can move.
Walt
Old 11-15-2006, 02:40 PM
Thanks, Walt, for your suggestions. As there is no noticeable 'play' in the steering, I dismissed linkage 'issues' as being a problem. However, I will now take a look at the things you suggest.
Geez, you folks are certainly giving me plenty to do during Oregon's rainy season.
Gordo
'88 Targa
Old 11-15-2006, 10:55 PM
