alignment question
What is an acceptable difference in camber settings left to right? My max settings are 1.9 left front and 1.6 right front, and 2.6 left rear and 2.3 right rear. Is this an acceptable range or do I need an adjustment? The other problem I have is the right front was rubbing, so I cut then rolled fender lip and it cracked how do I handle that? Apparently I'm the only guy with the right side too tight,go figure.
Old 10-09-2006, 08:11 PM
Chuck Moreland's Avatar
I like to see within .1 degree, side to side. With your current setup the car is likely to pull left.
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-09-2006, 09:55 PM
Thanks Chuck, the alignment specs I'm using are actually the ones that you gave me over the phone. Is it uncommon to max out on these numbers? I should mention that I have the monoball camber plates from Automotion that I bought years ago. The car doesn't seem to pull, and is certainly much tighter. I'd like to get the numbers to match because I'm afraid that pushing the left out will cause that tire to rub. My wheel tire combo is 16x7 951's in front and 16x8 911 rear and Michelin Pilot sports. My ride height wound up at 25 1/8 and 24 5/8 so I don't think I'm too low.
Old 10-10-2006, 04:22 AM
